no fire
Old Nov 9, 2006 | 09:44 AM
b69bama69's Avatar
b69bama69
no fire
i have a 95 f-150 4.9 i6, just replace fuel filter and one fuel pump, after this truck run fine for a little while then started spitting and sputtering now wont crank at all. started checking things out and im not gettting any fire. ign module is good, what else should i check?
Old Nov 9, 2006 | 03:14 PM
Ranger GT2's Avatar
Ranger GT2
You need to see if your getting voltage to the module. Sounds like you may have gotten a bad connection somewhere. Ignition switch possibly? Possibly a bad ground to the computer. You may want to post in the elecrical forum if you don't get anymore responses. I have used it a few time and they have been very helpful.
Old Nov 10, 2006 | 05:04 AM
Ranger GT2's Avatar
Ranger GT2
You may also want to verify the distributor shaft is actually turning when the mtor is cranked over.
