Question...im curious
Old Nov 9, 2006 | 06:50 AM
straightexhaust's Avatar
straightexhaust
I was replacing some brake components earlier this week and I was wondering whats the thing on the drivers side tucked in the frame rail that has about 4 or so lines going to it?
Old Nov 9, 2006 | 08:45 AM
MustangGT221's Avatar
MustangGT221
That has 4 brake lines going to it?
Probably the ABS module.
Old Nov 10, 2006 | 08:59 PM
theman79's Avatar
theman79
yeah it's the abs control module, and it cost around $400
Old Nov 11, 2006 | 10:57 AM
straightexhaust
ok good thing i dont need to replace it
Old Nov 11, 2006 | 11:57 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
don't even go near that thing. my 93 Bronco caught on fire one day when the sensor in that block failed. Ford said I had spilled some power steering fluid on it somehow.
that block is a bear to bleed when it gets air in it btw
Old Nov 11, 2006 | 06:59 PM
DBANDGB's Avatar
DBANDGB
Rear Anti-lock
IS THERE A SPECIAL WAY TO BLEED THAT BLOCK?
Old Nov 11, 2006 | 07:03 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
I don't know. I tried and tried, and eventually took it to the dealership
