tranny question
Old Nov 8, 2006 | 06:39 PM
JET EDWARDS's Avatar
JET EDWARDS
Red face tranny question
i have a 1990 f250 and need to figure out what kind of transmission is in it. it has 14 bolts on the trannypan and it has 3 splines. the shifter does not hav an o/d button. the column shifter reads P R N O/D D 1 the tag has these numbers on it
PKB AJ1
011987 L21
E9TP TC I CANT FIND ANY INFO ON IT AND WHEN PROMPTED ON DIFFERENT SITES TO PUT IN ID NUMBER IT SAYS ITS SORRY.....
Old Nov 8, 2006 | 07:22 PM
JH50's Avatar
JH50
Try this if you haven't!!!
HI!,
Take the transmission pan off, pull the filter. Take the pan and the filter to your local Ford dealership. Tell them you want a filter kit for your truck, that may lead to them being able to tell you the type of tranny you have.
If you or someone before you replaced the tranny in this truck and used one from a differant year or size truck that could also be the problem with identifying it by the numbers.
THE RETAILERS ONLY KNOW WHAT THEIR COMPUTERS TELL THEM FROM THE INFO THEY IMPUT!!!
Another possible way to find out what you've got is to pull the valve body. It's easy to get out and differant transmission almost always have a differant valve body.
Take it to the dealership or maybe better a Transmission repair shop and see if they can find one. If they can that may lead to finding out the info you need.
Hope this helps!
Good luck!!
JH50
Old Nov 8, 2006 | 07:26 PM
JET EDWARDS
thanks for your help
Old Nov 8, 2006 | 07:31 PM
JET EDWARDS
also another question
my step father says the transmission i need is a f1od can anyone tell me where i can see a picture of this or any info of prices or anything thanks
Old Nov 8, 2006 | 11:54 PM
NORTY1's Avatar
NORTY1
the trans you have is an AOD, the aod and aode trans have 14 pan bolts, the C6 has 17 bolts. If you google search ford aod transmissions you will find a few sites about them, there is a really good site called PATC speed shop they have lots of parts and info. they also sell whole units if needed. hope this helps
Old Nov 14, 2006 | 10:01 PM
JET EDWARDS
thanks alot it was an aod got 1 for 200 at junk yard
Old Nov 14, 2006 | 11:59 PM
gumbydamit's Avatar
gumbydamit
Day late & a dollar short but I found this link - check the door tag and compare.
https://www.ford-trucks.com/article/...ers_Guide.html
Old Nov 15, 2006 | 08:00 PM
JH50's Avatar
JH50
Glad you found what you needed!!!
Old Nov 15, 2006 | 08:18 PM
JET EDWARDS
Talking
thanks iwas puttin the thing in until 10 last night via coal miner light. test drove it and the gears now engage good but still seems that the engine puts forth more speed than the truck goes. oh well ill look on to see what to do next
