Sponsored by: Kumho
Right side front tire isnt centered!
Old Nov 8, 2006 | 01:36 PM
BarnacleBob's Avatar
BarnacleBob
Unhappy Right side front tire isnt centered!
Whats up yall, I have a 92 f250 4x4 351. My problem is that my front right side tire isnt centered and i was wondering how i would go about bringing in that tie rod to straighten her out. Is it the adjuster sleeve, im not really sure. I also have another question dealing with my left rear wheel cylinder, I seen it this afternoon and brake fluid had leak all out. What should I do?
Old Nov 8, 2006 | 03:59 PM
andym's Avatar
andym
You need an alignment if you need to change the toe-in unless you *really* know what you're doing. As far as the brakes go, I would make sure it's not gear oil you're seeing. If it's brake fluid, don't drive it until you replace whatever's leaking.
