Climate Control Problem
Nov 8, 2006 | 08:45 AM
Hey all, I have a 91 F-150 XLT. The Climate Control will only blow air out the deftrost setting. It will turn off if I switch it to off but will not blow out vent, floor, etc. Any ideas on what the problem may be and how to fix it. Thanks!
Nov 8, 2006 | 10:13 AM
the vacuum line has a leak.
remove glove box and look at hose and if ok look under hood.
Nov 8, 2006 | 12:25 PM
Is it also possible that the control head is bad?
Nov 8, 2006 | 01:23 PM
maybe, but probably not.
do a search on heater control.
it is more than likely a vacuum leak.
just follow all the hoses and you will see that one is not connected or cracked.
Nov 8, 2006 | 10:32 PM
OK, I found out I need a Vacuum Reservoir Cannister (looks like a coffee can.) Any ideas on where to get one? I have scoured the internet and can't find one anywhere.
91 F-150 5.0L
Nov 9, 2006 | 08:47 AM
go to column on left and hit national parts depot.
they are a sponsor and have them.
you can get a catalog with you first order.
glad you found the leak.
some have made thier own can replacement.
Nov 9, 2006 | 09:45 AM
I just wrapped duct tape around the can covering the holes. Works like a charm now. Does this can have something to do with cruise control as well??
Nov 9, 2006 | 10:09 AM
Cruise control on my truck is a second can on the driver's side.
Nov 9, 2006 | 10:11 AM
OK, thanks. Mine doesnt work, but I think it is something electrical.
Nov 9, 2006 | 10:20 AM
could be fuse or wiring or clock spring in steering column or vacuum leak that causes cruise not to work.
that was a real Red Green fix you made with the duct tape.
Nov 9, 2006 | 10:46 AM
Yeah, you like that one...cheap too...
Already checked the fuse...
