Sponsored by: Auxito
Is it my starter?
Old Nov 8, 2006 | 12:00 AM
TKAT79's Avatar
TKAT79
Is it my starter?
This is on a '98 F150 4WD
I turn the key to start and it does nothing. No clicking or anything. For as long as I hold the key to the start position, the dash lights stay off but as soon as I release the key back to the ACC position the dash lights come back on. All the lights look to bright. It isn't the battery, I tried to jump and no luck. I tried to bang on the starter .. and it makes a weird noise now when I try to start it.
I'm going to get a new starter tomorrow, so hopefully that's the problem. As far as I can tell it's the original starter.
Thanks.
Old Nov 8, 2006 | 12:15 AM
Baja FX4's Avatar
Baja FX4
Thanks.
If you have or can get a voltmeter just make sure that you do get 12 volts to the starter before you do anything else.
If you have high resistance in the wire that goes from battery to starter and the voltage is low,it will do the same thing.
If you got 12 volts there and 12 volts at the small terminal that comes from the switch when the switch is turned to start.
Then your starter is faulty.
Or even if you do decide to remove the starter,have it tested.places like autozone of checkers will test it for free.
Good luck.
Old Nov 8, 2006 | 12:30 PM
mneal's Avatar
mneal
I vote it will be starter.
Old Nov 9, 2006 | 11:24 PM
TKAT79's Avatar
TKAT79
Update ..
It was the starter .. $109 for the starter and $65 to have it put in. Considering the time it would have taken me to do the job, I think that was pretty cheap.
Thanks for the replies guys.
Old Nov 10, 2006 | 05:02 PM
DMch's Avatar
DMch
I had the same thing last month. $159CDN and 3hrs to put it on.
Old Nov 10, 2006 | 09:40 PM
TKAT79's Avatar
TKAT79
Sucks, unexpected expense. But the truck fires up on a dime. I love it. No more wondering if it's going to start or if I have to get under it and bang on the starter.
Old Nov 11, 2006 | 01:24 PM
thehawk789's Avatar
thehawk789
when starters fail they go high amp draw.... Pulling all the power away from lights and anything else.
Old Nov 11, 2006 | 03:53 PM
DMch's Avatar
DMch
It did not when mine failed. I did the same as TKAT79, tried to boost it and still had lights radio and dash lights.
Old Nov 12, 2006 | 12:36 AM
thehawk789's Avatar
thehawk789
well for one you should have a starter relay, and it should click when you turn the key. If it is not clicking you can have 1 of 4 things wrong. Lack of power to the hot sides, lack of ground to the starter or the pcm or bcm, I'm not sure which switches to ground on Fords. But if the starter relay is clicking and you are not starter is not engaging, its a bad starter. YOu could try hitting the starter with a hammer while someone holds the key in the start position, if it starts with that-bad starter. I shouldnt say that your lights and things wont work at all, they will probably just dim a little more during attempted cranking. Your battery is probably at least a 600 amp battery, so if the starter is taking 200 A, there is still plenty left for lighting. Normally a starter shouldnt draw more than 200 A on any light duty truck. 125 A is a good number for a V6, A V8 probably draws around 150-175A. Bad starters draw more.
Oh, by the way, how is the battery? Have you checked to see if it is charged? Or had it tested? Maybe you have a corroded battery cable and the resistance is too high to allow enough current to flow to the starter. The lights should not go totally out when cranking, they should only dim somewhat.
Old Nov 12, 2006 | 09:55 PM
hwfeuss's Avatar
hwfeuss
Check the TSB below. Happened twice to me. My dealer billed me about $30.
Your starter is probably fine. Point the ealer to this TSB!
https://www.ford-trucks.com/tsb/full...hp?tsb=01-21-8
Good Luck.
Old Nov 13, 2006 | 01:52 AM
firedog4689's Avatar
firedog4689
I have a 97 F150 4x4 with the 4.3 V8. This is probably your starter but I would like to add to the diagnosis of "locked down". I drove to my daughters school one day and parked, came back out and hit the starter. The motor turned over two times and BANG-CLANG real loud. After that nothing just the click when hitting the starter. I thought there goes the motor, but Im not one to give up easily so I kept hitting the starter. The tenth or so time, BANG-CLANG, started right up! Ran great, backed out and had no power steering! The shaft in the power steering pump shattered and locked the dang motor down. It was so badly damaged I couldnt even get my core charge! Anyway, thats my two cents worth.
Old Nov 13, 2006 | 09:28 AM
TKAT79's Avatar
TKAT79
The cables and/or ends did not have any signs of corrosion on them. It was the starter. Thanks for the heads up on the TSB though.
