Rearend Conversion
Old Nov 7, 2006 | 11:44 PM
78F150XLT's Avatar
78F150XLT
Rearend Conversion
Hey, i am a proud owner of a 78 ford f-150 XLT ranger with a big old 351 cleveland and my rearend blew. my axle gears went. i was wondering since it is a limited slip rearend, can i change it to a true pozzy. like i took the clutches and the axle gear with no flange on the back out, and i put the other axle gear in the hole which the clutches gear went into and it fit but it had a little bit of play inside there. Shouldn't the axle hold it inplace? or just scrap the whole idea cause its no possible and just leave it as a limited slip?
Old Nov 7, 2006 | 11:50 PM
Mil1ion's Avatar
Mil1ion
Welcome to the site
Where did that 351 Cleveland come from ?
They quit making them in 1974 and never put them in trucks
Posi is a GM term.
On here it is Limited slip or Traction Lok.
You are best asking specific differential questions in the drivetrain forum.
That's where the axle guys hang out.
Old Nov 7, 2006 | 11:54 PM
78F150XLT's Avatar
78F150XLT
its out of a 72 BOSS
Old Nov 7, 2006 | 11:57 PM
78F150XLT's Avatar
78F150XLT
ok i'll ask them there then... thanks for the help!
Mil1ion's Avatar
Mil1ion
Here's a link to it.
https://www.ford-trucks.com/forums/forum69/
Where are you near city/town (from the farm) ?
Old Nov 8, 2006 | 12:02 AM
78F150XLT's Avatar
78F150XLT
Edmonton is the closest city, but if you really know alberta, longlake prov. park is like 5 minutes north of my house
Old Nov 8, 2006 | 09:30 AM
samickguy15's Avatar
samickguy15
If you want both wheels to spin(or hook) at all times, then buy a spool. A spool locks the axles together. A spool will cause the tires to chatter when making sharp turns and will also increase tire wear in general. If you want a streetable form, buy a locker, not a posi or limited slip, but a locker. If you want to have a nice quiet smooth way to spin/hook both wheels, stay with the Ford traction lock or a similar limited slip.
Old Nov 8, 2006 | 06:25 PM
78F150XLT's Avatar
78F150XLT
k but swaping that gear wouldn't work? like i threw it all together back in the gear houseing and it seemed to work...
