"Anyone having a problem with their 95 F-150 like this?
Start up, idle goes to 1k, engine light blinks 4 times and idle jumps to 1.5K.
Idle starts to reduce toward 1k again the engine staggers. After that it slows the idle to 800 RPM.
I replaced the EGR valve, plugs and cleaned the fuel idle plates. Replaced the fuel filter.
Hooked to the computer it will not return any error codes.
Any Ideas folks?
Spliceman"
Since I last posted I have exchanged the IAS sensor, disconnected the battery cables (My way of rebooting the computer) and checked out the wirring. All for not. The shop I have been taking it to has no idea what else to do. They have thrown up their hands and cried "Uncle".
Maybe the computer is the problem? Should I jack up the radiator cap and drive another truck under it?
Help,
Spliceman02
Reason: Grammer
Man, that definetly sounds like the computer is going into self-test mode ... Check by the driver side hood hinge... The self-test plug is on that harness, make sure that its not stripped or something and grounding itself out.
I kinda side with MemOrex. Sounds an awful lot like it's running a KOER test. Has it been in the shop for anything lately? If not, and this problem just showed up by itself, I'd check to make sure something hasn't pinched a wire harness somewhere. I keep seeing "The EEC's bad, Replace it" in here like all of us have a roll of $100 bills in our pockets or something. I say go for the simple stuff first, which is usually the cheapest to fix anyway. Based on my experience with EEC's (take a peek at the junk I own below) it takes a LOT to kill one of them. It's a stretch (literally and figuratively), but perhaps the diagnostic plug got caught in the hinge on the hood or something.
Most of us are in here to save a buck or two, or just simply don't trust dealerships and "certified" mechanics any more. So, obviously, some of us are going to suggest some pretty simple stuff. The EEC's one of the last things I'll point at. They're just too rugged in my experience.
