who builds the most Dependable Longest Lasting truck on the road
#91
... that old Buick head had the valves on the same side of the chamber. It was a design that nobody has copied and it made for one of the worst exhaust ports ever seen on an overhead valve V8 engine. It literally had the exhaust travel all the way across the head, from the intake side of the head, across the top of the combustion chamber (and under the valve cover), to the exhaust side of the head. The "nailhead" was a truly bad, awful design.
Regards, Eric
Regards, Eric
#92
The newer Buick aluminum V8 and the iron V6 that grew from it, while clearly an evolution of the nail head philosophy, didn't have that same, lame, exhaust-all-the-way-across-the-head design. They actually addressed that shortcoming by flattening the chamber and by allowing the exhaust to exit higher on the head and earlier via a much shorter port that exited before the end of the head. (It's really difficult to explain.) Yes, they are all pretty narrow for 90 degree designs. I agree that the intended purpose didn't require a high flow head but what bothers me is all that heat being shed back into the head from those long tortuous exhaust ports. I mostly just wanted to clarify to the other folks on this thread that NOBODY copied the nailhead design.
Regards, Eric
Regards, Eric
#93
A pentroof head is required for 4V operation - which was in the cards for both buick and olds - it has nothing to do with the valve placement and in fact with a SOHC design you can have a 4v pentroof chamber (read: honda 4vfc head) or a 2v pentroof using pushrods (read: mopar 4.7L +)
suffice to say, the "new" Hemi, when it came out about a decade ago owes a lot more in head layout to the buick, than to the hemi of old (This was told to me courtesy of Tom Hoover, an ex-neighbor, who explained it and a mutual friend on the fender of a car on the floor of the friends tranny shop - so Im kinda into believing it)
If you lived that close to Tom Hoover, and were so influenced by him, how come he didn't make you into a Mopar man?
Regards, Eric
#94
on
1 Post
Couldn't be more wrong here. You must have misinterpreted what Tom Hoover said. Both the old Hemi and the nailhead had a very "domed" Hemi chamber whereas the new Hemi chamber is flatter, much like a modern 4 valve. But other than that one change (well there's that dual plug business too but even that can be traced back to the 2nd generation race Hemis of the early 70s), the new Hemi is old Hemi all the way, right down to the double rocker shafts, which is yet another thing you won't find on the Buick. There's more to being a Hemi than just the chamber design although that is of course where the name comes from. Again, there is not one feature or design element in the new Hemi head design that can be attributed to the old Buick nailhead. Not one. The nailhead was a cheap, substandard copy of the original Hemi, plain and simple. It technically had the chamber, but nothing more. And it was the old, severely domed style hemi, just like the original Hemi, not the flatter new style we have now. The new Hemi is a new, improved copy of the original Hemi, plain and simple.
Of course, why take words for it. you can always look here: The new Dodge Hemi V8 engine in full detail - 5.7, SRT8 6.1, and 392 6.4 and scroll to the picture of the combustion chamber.
the shape of the chamber is unmistakeably pentroofed
#95
OK, so is it the quench that you are fixated with? The Buick nailhead was not the first engine to use quench but I will grant you it may have been the first "Hemi" type chambered engine to use quench. OK? But even those quench pads are located differently in the new Hemi with the quench pads running along the sides of the chamber on both sides of the valves as opposed to the nailhead's pads which are on each end of the chamber. And the Buick nailhead's quench pads are so small they are hardly worth mentioning! The Boss 429 was another "Hemi" type engine that used quench as well and I am sure that there were/are others. None of this hardly qualifies as anybody "copying" the nailhead.
And again, for the record, I'm not saying the Buick nailhead breaths poorly because of any thing to do with it's chamber, I'm saying it breaths poorly because of it's poor valve locations and poor port locations/port layouts/port designs as well as the fact that putting both valves on the same side of the chamber forced the valves to be too small hence the name: "Nailhead" because the valve heads resemble the head of a nail.
Also, for the record, the engine that replaced the nailhead, the Buick 400/430/455, is a pretty decent design. It is in fact my favorite GM big block!
Now, lets look at a cutaway of the nailhead:
http://image.carcraft.com/f/9579816/...mage_large.jpg
and the first gen Hemi:
http://image.carcraft.com/f/9778400/...power_hemi.jpg
and the second gen Hemi:
http://image.carcraft.com/f/9778406/...4_426_hemi.jpg
and the third gen Hemi:
http://image.carcraft.com/f/9778412/..._5.7l_hemi.jpg
Like they say, a picture is worth a thousand words! So, four pictures should be worth four thousand words!
That Buick chamber sure looks domed to me! It's by far the most domed chamber there! Even more than the original Hemi!
Do you see the progression AWAY from the steep domed design of the both the original Hemi and the nailhead Buick? Again: There are NO uniquely Buick nailhead design features in ANY Hemi or ANY 4.7 Mopar or ANY Poly head Mopar or ANY other Mopar or ANY other engine!
You want reading material? Here is some reading material: New DaimlerChrysler Hemi Engine - Car Craft Magazine and: Pontiac Firebird - Car Craft Magazine and: Buick Nailhead - History Of - Car Craft Magazine
BTW, one of those articles was listed as a source in that Allpar article you linked.
Regards, Eric
Regards, Eric
#97
You could do the same thing you know. Go ahead and post it. But what does the quad 4 have to do with your assertion that there are Buick nailhead design features in the new Hemi? My focus was to show that, contrary to what you would have us believe, the new Hemi moved AWAY from the chamber shape of the nailhead, not towards it. Yes, the quad 4's chamber, just like most all of the other decent modern 4 valves out there, is closer to what the new Hemi was/is trying to emulate. You would have had a better chance if you had started out with that argument instead of the nailhead one. Maybe that's why you are bringing it up now....
For the record though, the quad 4's chamber broke no new ground. There were already plenty of nice, well designed, compact chambered 4 valve heads out there when the quad 4 debuted.
You can call these chambers by whatever names you want to. It doesn't matter. Look at the pictures again and post one of the quad 4 too. The new Hemi has VERY LITTLE resemblance to the nailhead.
BTW, since you like throwing names around, "Hemi" is short for "Hemisphere" which means "half of a sphere". The original Hemi's chamber was a true "half of a sphere" while the new Hemi and the modern 4 valves have had their "spheres" squashed somewhat.
Regards, Eric
Regards, Eric
#98
Getting back on topic, I was at the U-Pull-It today getting a fuel injection "spider" for my "CPI" equipped 95 Blazer. All of the Blazers and Jimmys and S10s and S15s and Sonomas etc. etc. and so on, ALWAYS have their spiders removed. It seems like they are gone even before they even hit the ground. But I've discovered that the CPI 4.3 was also an option in the Astro minivan and it's GMC equivalent so I've been on the hunt in the minivan section too. Unfortunately, I'm not the only one who knows CPIs can be found there so the pickings have been pretty slim there too. But today was my lucky day and I found one! Anyway, while I was toiling away inside the Astro getting my Spider, I saw the Astro's owner's manual there. On the cover it claimed "The longest lasting trucks on the road". Now we know that back in the mid-90s when this Astro was made Chevy was still claiming that title but they were apparently also including minivans in their figures. Were all the manufacturers factoring their minivans into their figures? Were they all taking the R.L. Polk registration stats for both trucks and minivans and lumping them together to skew the results? I've always thought of minivans as throwaway vehicles but if you think about it most of them live pretty easy lives, not towing too much, not carrying loads that are too terribly heavy, usually being driven by the least aggressive driver of the family (Neither the teenage kids nor the Dad want to be seen in it), I'm pretty sure Chevy and I know Mopar have sold and continue to sell more minivans than Ford does, maybe this is how they've been skewing the results!
Regards, Eric
Regards, Eric
#100
I don't know, you tell us! You are the one who has one!
What I am saying is most minivans live pretty easy lives, not towing too much, not carrying loads that are too terribly heavy, usually being driven by the least aggressive driver of the family (Neither the teenage kids nor the Dad want to be seen in it), which may mean they live fairly long lives since they aren't being worked too hard or beaten to death. This would help a manufacturer pump up it's longevity stats. Just a crazy theory on my part but I can't think of any other reason why the manufacturers would include the minivans in their stats.
Regards, Eric
Regards, Eric
#101
on
1 Post
You are right, I could have. But I worried it would do no good, so I didnt. You see, when you keep posting pictures of heads that are clearly, to the naked eye 'pent' roofed (again, lookup what makes a 'roof' or chamber pent or not) yet calling them 'hemi', I feel there is no point.
As I said, I could care less where the valves actually were as they were irrelevant to chamber shape. the Q4 engine however, was a different animal in that it was not 'hemi' by purist definition, but it was not 'pent' at all and any competent picture of one might 'learn ya a little'.
Your argument reads as thus: "I have a sphere here, but to get it in my locker I smashed it on all sides, but its still a sphere - see?"
#102
Regards, Eric
Regards, Eric
#103
Regards, Eric
#105
Regards, Eric
Regards, Eric
The dividing line for R. L. Polk may be if it is registered "commercial". In that case, a cargo van would be a truck, while a passenger van would not. Example, Ford E-series, commercial cargo van or Club Wagon. One is a truck, the other a passenger vehicle. The numbers of these things is probably too small to skew results compared to pickup trucks.
