Carb. question
Old Nov 7, 2006 | 04:30 PM
82F150Beast's Avatar
82F150Beast
Carb. question
I have a 1 barrel carb and I was looking to upgrade to a 2 barrel carb. Can anyone please tell me what all is involved in doing the swap? Thanks much.
Old Nov 8, 2006 | 06:36 AM
teds74ford's Avatar
teds74ford
I put my motorcraft 2150 on an offy C series with a mr gasket adapter (which sucks) and made my own throttle bracket. The adapter was a 4 to 2 bbl, but it didn't seal at the back of the carb, so the adapter needed a sheetmetal adapter.
Old Nov 9, 2006 | 12:51 PM
mattri's Avatar
mattri
Check out clifford.com they have an adaptor that will go between your intake manifold and the new carb. It's pretty straight forward, you may need to modify your throttle linkage a little or re-route a vac line or two but it's no big deal.
Old Nov 9, 2006 | 04:25 PM
82F150Beast
Thanks for the info guys.
Old Nov 10, 2006 | 07:34 PM
Steamir's Avatar
Steamir
There are many threads on this topic. If you do a search you'll learn quite a bit.
