Oil & Lubrication
lubricants?
Old Nov 7, 2006 | 03:47 AM
HighboyMac's Avatar
HighboyMac
lubricants?
So...when it comes to good grease....what do ya'll like? I am thinking that using a thicker tacky waxy sort of chassis lube is better. Seems that most of the greases I have used in the past for u-joints always looks like oil when I take the joints apart. What about Lubriplate? Seems like a good grease in u-joints and ball joints should be skookum (there is a red neck word for ya) to handle the abuse. Doesn't seem like it should turn into 75-85 gear lube after a while. What do you think?
Cheers
Bill
Old Nov 7, 2006 | 06:04 AM
Torque1st's Avatar
Torque1st
Posting Legend
Moved to proper forum.
Old Nov 7, 2006 | 10:47 AM
jimandmandy's Avatar
jimandmandy
I use Valvoline greases and never noticed them separating back into oil like I used to see with cheaper brands. The synthetic blend grease has moly in it so it meets the Ford spec for wheel bearings.
Jim
