Bronco II Ford Bronco II
No Brakes!
Old 11-06-2006, 10:53 PM
darrenmike's Avatar
darrenmike
darrenmike is offline
No Brakes!
I've got an '89 Bronco II. After letting it sit for about 2 months, I decided to drive it and my brake pedal went straight to the floor. The brakes didn't work at all. I've replaced the master cyl., bled the entire system. Found leaks in the wheel cylinders in the rear. Replaced them. Bled the system again. As long as the vehicle is off, I can get great pressure on my brake pedal, but as soon as I turn it on, it goes straight to the floor again. I'm stumped, anybody have any ideas?
thanks
Old 11-06-2006, 11:40 PM
Help I M Stuck's Avatar
Help I M Stuck
Help I M Stuck is offline
your power brake booster is probably bad. Sometimes the diaphram inside the booster dries out and cracks causing it to suck/blow air. It's happened to me in the past.
Old 11-07-2006, 12:18 PM
rebocardo's Avatar
rebocardo
rebocardo is offline
Agreed, power brake booster.
Old 11-07-2006, 11:59 PM
darrenmike's Avatar
darrenmike
Thanks!
You know, that is what I thought a couple of days ago, but I called 3 different parts stores and they all concurred that my booster couldn't possibly be causing my problem. I went and bought the booster today and put it in and guess what... I have brakes! Thanks guys!
Old 11-08-2006, 04:38 PM
my72ford's Avatar
my72ford
my72ford is offline
glad to here you have brakes on your rig!!
foot947
1999 to 2016 Super Duty
02-12-2024 09:45 PM
RedTaurus94
10-18-2012 05:06 AM
truszip
06-14-2007 07:41 AM
Bob in ND
06-21-1999 05:10 PM
Quick Reply: No Brakes!
