Modular V10 (6.8l)
need help bad !!!!!
Old Nov 6, 2006 | 05:10 PM
irishkev's Avatar
irishkev
Exclamation need help bad !!!!!
i have a '99 f-350 cab-chassis with a little over 103k. the other day i had the oil changed and replaced the battery that wasn't charging. went to the house and changed rear brake shoes. when i left to test drive the brakes, the engine stalled at a stop sign. had to turn key all the way back for it to restart. now it stalls all of the time when put in gear. it is also lumbering at an idle like it wants to die and then idles back up. i'm having to two foot drive just to get around. i replaced the IAC yesterday and it didn't do anything different. it seems like a vacuum problem to me now but, i couldn't find any leaks. no check engine light either. tried to run the scanner on it and i can't do the engine run test because the idle is too intermittent. any ideas???
Old Nov 7, 2006 | 02:39 PM
irishkev's Avatar
irishkev
never mind--fixed it-- please delete thread
Old Nov 7, 2006 | 02:47 PM
04XL4x4RC's Avatar
04XL4x4RC
What was the FIX? Did you just forget to hook something up after the replacement of the IAC?
Thanks,
Matt
