fuel injection replacement
Old Nov 6, 2006 | 03:43 PM
coreyl302's Avatar
coreyl302
I have a 91' f150 5.0 im wondering what everyone thinks about my problem my truck seems to sputter and shake so i got a code scanner and the scanner told me there is a problem with my #4 injector so do i replace them all or is there anything that takes a little less work to fix this problem?
thanks
Old Nov 7, 2006 | 08:11 PM
mauicruza's Avatar
mauicruza
Getting to the injectors on these trucks aren't that hard. You only have to remove the upper intake. You will need to rig up a T40 torx bit with a long extension to get to one of the center bolt. Then remove the (4) hold down bolts that secure the fuel rail.
Most shops will recommend replacing all the injectors but I've had a couple vehicles where I replaced only the bad injector and haven't had a problem but it's basically up to you. Just remember to replace the orings with new ones.
Old Nov 7, 2006 | 08:17 PM
EPNCSU2006's Avatar
EPNCSU2006
What kind of code scanner can tell you that on a 91?
Old Nov 8, 2006 | 02:23 PM
coreyl302's Avatar
coreyl302
ive used expensive ones and cheap ones they all tell you the same information its just harder to read with the less money you spend
Old Nov 8, 2006 | 05:37 PM
EPNCSU2006's Avatar
EPNCSU2006
That's what I'm getting at. The 91 shouldn't be able to tell you anything about specific cylinders since it fires the injectors in batches of four.
Old Nov 8, 2006 | 10:34 PM
mauicruza's Avatar
mauicruza
I'm curious too. Please let us know what brand and cost because I haven't seen one that can do that for the batch fire.
Old Nov 9, 2006 | 06:24 PM
LxMan1's Avatar
LxMan1
He probably got a #4 cyl. code from the balance test. OBD-I didn't specify cylinders like the OBD-II does.
Old Nov 9, 2006 | 06:42 PM
EPNCSU2006's Avatar
EPNCSU2006
Only SEFI does the cylinder balance test (OBD-I will give a cylinder number for the balance test). A 90 truck is not SEFI, it is batch injection and cannot do a cylinder balance test nor can it pinpoint a cylinder (unless it's some super fancy scan tool).
Old Nov 9, 2006 | 06:57 PM
coreyl302's Avatar
coreyl302
so what does a #4 cylinder mean
Old Nov 9, 2006 | 08:16 PM
EPNCSU2006's Avatar
EPNCSU2006
I'm not sure exactly what the output of the code scanner was. You can do your own cylinder balance test by pulling the connector off of one injector at a time and note the rpm change. If the rpm drops less for one cylinder than the rest, that injector isn't injecting enough fuel.
