I dissagree.. a 250 could easily pull that, even mine with the 3.73's is rated for 10k
the trailer weighs 6k unloaded, 8500 loaded. 2500 lbs is alot of food/water/vacation crap....
??????????????? A 250 is a 3/4 ton truck! ?????? Did I miss something? I pull over 8000 with my 150 with no problem. The 250 will pull it better thats why I said borderline 3/4 ton. The 1 ton would be the 350.
The way you wrote it, I thought ya meant he had to go higher
