Sponsored by: Real Truck
electrical connector needed
Old Nov 5, 2006 | 08:46 PM
Stazworks's Avatar
Stazworks
I am in the process of reassembling my 2000 dually after a full paint job and I went to put the box harness back in and the connectors for the flare marker lights are cracked and the pins are rotted in half inside.
I have been searching theweb and can not find who would have the factory conectors to fix the harness. I will try ford in the morning but I am kinda looking for what company would sell the connectors and pins.
John
Old Nov 5, 2006 | 10:05 PM
ReAX's Avatar
ReAX
That should be 194 twist in correct?
Dorman www.dormanproducts.com
Standard has this http://www.smpcorp.com/wmimages.asp?...&partnum=S-816
I would start there, most any shop will carry both manuf's
Old Nov 6, 2006 | 08:41 AM
Stazworks's Avatar
Stazworks
I apreciate the help but neither sorce had the right part.
What i am after is the plug that the bulb goes in, it is a little gray plug that the bulb goes in one end and a connector goes over the other end. I have three of them that the pins are rotted off inside.
I also need the connector and the female pins to fix the harness.
John
