Weird Electrical Issue and Battery Question
Here are the symptoms:
1. Step on the brake and the clock display goes away. Let off brake and it returns.
2. Turn on the lights and the overdrive goes on and off repeatedly.
Everything seems to work otherwise. Seems like there is not enough electrical power... Is this a symptom of a bad battery (or 2 - diesel has two) or connection(s)?
One possible related event is that during the news reports of speed control deactivation switch fires, I disconnected the electrical lead to the switch on the master cylinder and then reconnected it when I found out F-250s were not effected WITHOUT disconnecting the batteries first. Hopefully I will not have to pay for my indiscretion. ;-)
Now the question: the 2 batteries are connected in parallel. Are there any special procedures for disconnecting the batteries other than removing the negative cables first?
Thank you,
Will
As far as the batteries go, as long as you diconnect both grounds first you can remove them any way you like.
And as far as the deactivation switch, it is highly unlikely that you'd do any damage by disconnecting it with the batteries connected.
Thanks for the suggestions. Forgot one thing; there is a camper on the truck currently (circa 1972 that I purchased with my 1972 F-250 project truck). I wonder if I disconnect the camper plug if the problem goes away. Used to work fine until recently... Time to divide and conquer this problem.
Regards,
Will
