head identification
Old Nov 5, 2006 | 05:58 PM
trlawman's Avatar
trlawman
Exclamation head identification
i am rebuilding a 460 my block is d1ve a2b and my heads areare d3ve a2a are these a set of good heads or should i get something different
Old Nov 5, 2006 | 08:02 PM
WILDEBILL308's Avatar
WILDEBILL308
That depends on what you are going to do with this bild. The D3s as with all cast iron heads need some serius work on the exaust side. They will do aney thing you need till you need the extra flow of big aluminum heads.
The D3s ar a lower compreson / emishon head. Knowing that you can ajust to give yourself what ever compreson you need. I personaley woulden't spend the silley money for DOVE heads as they still need to be worked to get desent flow numbers.By the way welcom to FTI.
God luck
Bill
