Sponsored by: Innova
Adding an Amp?
Old Nov 5, 2006 | 04:37 PM
rtazz2000's Avatar
rtazz2000
Exclamation Adding an Amp?
What is the easest way to add one? will I have to hack open the harness?
97 factory cassette with 6 disk changer.
Old Nov 5, 2006 | 10:23 PM
ReAX's Avatar
ReAX
I bought metra's reverse and replacement harness'. I soldier the two harnesses together and extended the rears to a line level converter. It made the amp install no cut and clean.
Old Nov 5, 2006 | 10:25 PM
ReAX's Avatar
ReAX
I did it that way because soldiering guns/irons and plastic dash boards are bad combinations once you get cut afew time and agravated. I was able to do most of the work at a table and then plug my harness in and route the wires.
Old Dec 22, 2006 | 02:08 PM
pen_field's Avatar
pen_field
What did you do, I have a 97 with the factory seperate amp(dont know where it is though) and want to install aMTX amp and read that the speaker output behind the head unit doesnt have enough signal for the aftermarket amp..what do I do Thanks
Old Dec 30, 2006 | 10:40 AM
cln2po's Avatar
cln2po
For factory amplified systems you can grab signal either at the OUTPUT of the factory amp or at the speakers. I recommend a high power line out convertor - dont get a cheapy.
Old Dec 30, 2006 | 01:01 PM
pen_field's Avatar
pen_field
Thanks, I bought a Scosche SCL-4. It was the only thing that Crutchfield had but was only 20 bucks. Can you give me the info on a good oroduct. Also the factory amp is tucked tight in a hole below the head unit(hard to access) and the front speaker wires, where they come through the flexible rubber boots between the door and jamb, come in to the cab so high up that you cant even see them....This shouldnt have to be so hard...Again thanks.
Old Dec 30, 2006 | 01:53 PM
cln2po's Avatar
cln2po
That Scoche model should work fine - and at $20 seems like a great deal.
Old Dec 30, 2006 | 02:00 PM
pen_field's Avatar
pen_field
Can I get enough signal directly behind the head unit or do I have to get it from the factory amp (which I cant see how to access.) Accessing the front door speaker wires through the flexible rubber boot is hard also. I can access the rears as I fishe the wire thru the boot on the 3rd door. These 97 f-150 with premium sound seem to be a pia. thanks for your help.
Old Dec 30, 2006 | 02:03 PM
pen_field's Avatar
pen_field
Sorry , you answered the question already..signal at factory amp output...Wish I could figure out how to get under the factory amp...
Old Dec 30, 2006 | 04:09 PM
cln2po's Avatar
cln2po
Are you adding a 2ch or 4ch amp?
and is it for front/rear/sub/all ???
Old Dec 30, 2006 | 06:27 PM
pen_field's Avatar
pen_field
I am adding a Rockford Fosgate 4 channel to power a set of thier components up front and some coaxials in back. I am already feeding a powered sub from the rear speakers w/ the speaker level inputs. I am told the 4 channel amps rear channel can also get signal from the rear speakers but I will run the rears to the Scosch LOC first as well as the fronts...just dont know where to get to the front speaker outputs easily.
