sick 4.9
Old Nov 5, 2006 | 12:43 PM
tjc transport's Avatar
tjc transport
i ain't rite
sick 4.9
i did a tuneup on my neighbors 90 F150 4.9 auto trans last Sunday. the truck has 175,000 miles on it.
i told him to put a can of seafoam in the gas tank, cause it was still running a little rough, so on Monday afternoon, he poured a full can of seafoam in the gas tank, figuring that if the can said it is good for 30 gallons, it would work better with only had 1/4 tank.
then of Friday, he put 10 gallons of gas and a bottle of gumout in it.
this morning, he came over saying it was not running rite.
it has a dead miss, and runs like crap. i pulled the throttle body and cleaned it, cause it has never been cleaned. while the truck idles better now, it still has a dead miss.
this sound like a clogged injector, rite??
Old Nov 5, 2006 | 12:53 PM
quicklook2's Avatar
quicklook2
check the spark plug wiring order, real easy to switch 4 and 5.
are all plugs tight?
what exactly does 'tuneup' mean to you?
you did use motorcraft plugs, right?
Old Nov 5, 2006 | 01:01 PM
tjc transport
i ain't rite
motorcraft plugs, wires, cap, and rotor.
fireing order is correct. 153624
Old Nov 5, 2006 | 01:07 PM
quicklook2's Avatar
quicklook2
was it running rough before you started?
double check the plug wires are on the correct plugs, yes i know you wrote down the correct order.
what else did you touch when hood was open? maybe you knocked a vacuum line off or an elec. connector.
Old Nov 5, 2006 | 01:12 PM
tjc transport
i ain't rite
the truck was running fine after the tuneup, with the exception of a slight hesitation due to the dirty throttle body.
the problem started after the multiple high doses of seafoam and gumout.
Old Nov 5, 2006 | 01:53 PM
quicklook2's Avatar
quicklook2
maybe all the crap floating around after the seafoam fouled some plugs up.
o2 sensor may be suspect also.
Old Nov 5, 2006 | 01:57 PM
tjc transport
i ain't rite
the plugs are all clean, there are no trouble codes, and the cel is not on.
if the 02 sensor was fouled, it would throw a code or trip the cel, no??
Old Nov 5, 2006 | 02:07 PM
quicklook2's Avatar
quicklook2
maybe, maybe not.
may just have to drive it for awhile.
air filter and fuel filter replaced?
maybe reset computer.
