chime sound
Old Nov 5, 2006 | 11:35 AM
tclapp's Avatar
tclapp
Cool chime sound
I have a 99 explorer. the other day I started it and the check engine came on and it started chiming (five times then stops and starts again). Now when I start it no chech engine light comes on but still chimes (will chime the set then stop and repeat a few more time, never counted how many tho.) I called an auto place and they said with no light that they will not get a code......
any ideas on what the problem could be?
thanks
tclapp
Old Nov 5, 2006 | 11:49 AM
marragtop's Avatar
marragtop
There can be codes stored even if the CEL is out. Pull the codes and post them on this forum. Autozone will pull them for free. Call ahead to verify.
Old Nov 6, 2006 | 12:56 PM
tclapp's Avatar
tclapp
WEll no luck. I took it and it came up "PASS No Code R???" Don't recall what the last word was, but in short didn't come up with any code. It still chimes at me (five times then stops and starts again...for a total of like 3-4 sets). All my gages seem to be working right, CEL has not came back on since the first time....
Any ideas now?
thanks!!!!
tclapp
Old Nov 6, 2006 | 01:01 PM
marragtop's Avatar
marragtop
Try disconnecting the battery for 5 minutes to reset the computer.
Old Nov 6, 2006 | 01:27 PM
tclapp's Avatar
tclapp
Did that yesterday when I changed the oil......
Do you think because it is still chiming after that, that something is wrong? I was begining to think my wiring is just shot.
Old Nov 6, 2006 | 01:32 PM
marragtop's Avatar
marragtop
Are there any other indicators on the dash that come on when it's chiming? Maybe the seat belt indicator?
Old Nov 6, 2006 | 03:28 PM
tclapp's Avatar
tclapp
My seatbelt light comes on but goes off just as soon as I put it on, normally it is off (I have clicked it) before the chiming starts. No other lights come on...just the first time the CEL came on, but now nothing, just the chiming
Old Nov 6, 2006 | 04:00 PM
K2JJB's Avatar
K2JJB
could be your airbag system has an issue... that was covered in the following thread
https://www.ford-trucks.com/forums/4...ighlight=chime
five chimes every half hour, something to do with the airbag (in one case it was the airbag indicator light being burned out)...
Old Nov 6, 2006 | 04:13 PM
tclapp's Avatar
tclapp
Thats it problem SOLVED!!!! When we bought the explorer the airbag light was on. we took it to an electical place, they told us it was the sensor would not stay conected and there was making the light go off (or on, however you want to state it) So we have just left it, well now NO light but chimes!! It doesn't do it every half hour tho. But all the rest fits!!
Thanks a million everyone!!!! I will talk with the dealer to make sure its all on the up and up still tho.
tclapp
Old Nov 10, 2006 | 10:36 PM
MazdaRangerGuyInSTL's Avatar
MazdaRangerGuyInSTL
It chimes if the bulb is burned out.. to give you an audible warning since the visual warning doesn't work.
Old Feb 20, 2007 | 04:47 AM
b2trausch's Avatar
b2trausch
Hello, I'm normally on the Aerostar forum, but I'm troubleshooting the same problem on my daughters 2000 Mountianeer. Where is the sensor located so that I can check the connector? Thanks in advance for your help!
