Have another problem.
Old Nov 5, 2006 | 10:50 AM
pabs's Avatar
pabs
My truck when i first strat it fires right away but then it seems tto run ruff for a few seconds then i rev it breifly then shes fine.Also when driving i cruse for a bit and the voltage flickers and the headlight do the same but truck does not stall.The alt is new could it be the voltage reg?Where are the fusable links on the truck?
Thanks
Old Nov 5, 2006 | 11:50 AM
spikebee's Avatar
spikebee
You may have a glow plug or two burned out, that would cause the smoking and rough idle when cold. An easy way to test them is to hook a test light to the positive terminal of your battery then unplug each glow plug and touch the tip of your test light to the tip of each glow plug. If the light lights the glow plug is good, if not it's junk. As far as the voltage flicker, it's the glow plug relay cycling and it's 100% normal.
Old Nov 5, 2006 | 11:54 AM
spikebee's Avatar
spikebee
Sorry...As long as the flickering quits when the truck is up to operating temperature it's 100 percent nomal.
Old Nov 5, 2006 | 10:16 PM
pabs's Avatar
pabs
thanks bud.But i thought i saw it flicker when warm.It is very weird.
Old Nov 6, 2006 | 10:54 PM
PLC7.3's Avatar
PLC7.3
Put a signature up with truck info and we can answer directly to that year vehicle.
Old Nov 9, 2006 | 11:09 PM
pabs's Avatar
pabs
sorry its a 91 f-250 xlt lariat 5spd manual
