General Automotive Discussion
Ice scrapers
Old Nov 4, 2006 | 10:16 PM
eigenvector's Avatar
eigenvector
Ice scrapers
Yeah I know, you figure I would have gotten this down after 15 years of driving.
Seems like recently I've been getting those hard frosts that simply resist all attempts at scraping. Normally, its no big deal, scrape the frost and most of it will fly off. Sure there'll be some left on the window but its not a big deal. Lately its like the frost is adhered to the glass and all I seem to do is scrape off the top layer of frost. Can't even penetrate that armor plate of ice until the defrogger has loosened it up some. Feels like I'm gonna bust the back windshield clearing it up.
Then of course there's the inevitable battle of scraping off the mirrors without altering the mirror angles.
I've heard of the trick of using hot water to melt it, I tried that once when it was 20 below. I had the thickest and most slick patch of ice in my driveway and practically killed myself getting in the truck.
Old Nov 4, 2006 | 11:44 PM
furball69's Avatar
furball69
I don't know what to say but you must be getting some rain at night or something. Some of the scrapers have the gougers on the other side, those usually help break up stuff like that. and, as they say on the rigs "put out on it'.
Old Nov 4, 2006 | 11:51 PM
donjamer's Avatar
donjamer
The best advice I can give is get a remote car starter, then your problems will be over.. Scraping will be easy and the car will be warm..
Old Nov 5, 2006 | 05:34 AM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
Originally Posted by eigenvector
...........I've heard of the trick of using hot water to melt it, I tried that once when it was 20 below...........
That's a good way to crack a windshield . Assuming you live in a reasonably safe area and don't park on the street, go buy an extra key, start and lock truck, come back in five minutes and use the key on your keyring to enter the locked/running vehicle and drive away. I'd say furballs right, you're getting light/rain or mist overnight and it's more than just frost you're dealing with. That stuff almost needs to be removed with a chisel .
Old Nov 5, 2006 | 09:04 AM
john112deere's Avatar
john112deere
Yep, been there, done that.
It's still a pain, but it's a lot easier if you've got a good ice scraper. My mother gave me one a couple years ago that's a short handle, about 10", with a blade about 3" wide made of hard plastic that's about 3/16" thick. That'll take off thicker ice more easily than anything else I've used.
Even if you don't crack the windshield, I wouldn't ever use hot water to thaw out ANYTHING that's frozen. It may thaw it out, but the water runs down into places it shouldn't, and refreezes, and you're worse off than before.
Old Nov 5, 2006 | 10:27 AM
rebocardo's Avatar
rebocardo
Good way to crack a windshield or cause leaks around it. 10 degree plastic getting hit with 125+ degree water does not take it too well.
imo, The plastic used for scrapers today are inferior since the price point seems to be $1.
Old Nov 5, 2006 | 03:31 PM
eigenvector
Well I guess maybe the scrapers worn out, its seen about 3 seasons. I didn't realize that using hot water was a problem in that it would crack the windshield - and I just thought that huge patch of ice it left on the pavement was the problem.
As to those ice breakers on the back of the scraper - I always assumed those were stiffeners for the scaper blade. I never thought to turn it over and try to break it up that way. Either way, time to spend another 3 bucks for a new scaper.
Old Nov 5, 2006 | 05:14 PM
V X's Avatar
V X
Got an ice scraper at walmart a few years ago, it has a thin brass colored metal blade that works great and does not scratch the glass.
Luckily I don't have to use it much as my wife will start the truck on her way out the driveway. Boy am I lucky.
V X
Old Nov 5, 2006 | 05:30 PM
Old Rust Bucket's Avatar
Old Rust Bucket
Have you seen those heated ice scrapers that plug into your cigarette lighter? I wonder if they're all they're cracked up to be..
Old Nov 5, 2006 | 06:31 PM
eigenvector
V X
I owned one of those brass bladed scrapers a while back. I hated it, the blade would get bent and after that it wouldn't scrape ice for nothing. It wouldn't be so bad if you scraped straight-down, but you don't, you have to scape at an angle and so any bend in the blade will put one spot on the blade higher than all the others.
Old Nov 5, 2006 | 07:51 PM
cmpd1781's Avatar
cmpd1781
Yup. Extra keys and a locked truck, and about 10 minutes of warm up to loosen up the ice....along with a toasty cab is the key. If my neighbor complains about the thumping, growling 7.3 at 5:15am, I'll complain about his 120lb dog barking at 1:00am or 2:00am for no apparent reason. Fair trade.
Old Nov 5, 2006 | 08:09 PM
bigrigfixer's Avatar
bigrigfixer
The Pacifier
I had to scrape for the first time this season a couple weeks ago. Once was enough. So I moved some stuff around in my garage, and I park in there now. Somewhat warm truck, well, not cold, no frost to scrape.
Old Nov 5, 2006 | 09:16 PM
eigenvector
Man, I'd have a hard time getting a Cooper Mini (the real ones, not that dumb modern wannabe) in my garage. The door is 8 feet wide, I might get my Ranger in there if I drove carefully, but there's no way I'd get out without ripping the mirrors off. At 5 am, I just don't drive that straight.
Old Nov 5, 2006 | 09:20 PM
eigenvector
I actually can't do that where I am, it's illegal in my area to warm up the vehicles unattended. Something about a rash of car thefts due to people starting up the cars and walking away. Not that I would let a law like that stop me from doing it, its just that with my luck I'd close the door, lock the deadbolt, unlock the truck, start the engine, lock the door and close it, then discover I forgot the other set of keys and have to put my new back door to the boot test.
Old Nov 5, 2006 | 09:29 PM
cmpd1781's Avatar
cmpd1781
Keep one key in your wallet....Keep another key (as just an added-added safety precaution) in one of those tins with the magnetic backing and stuck to a "secret" place on your truck.........
We have "unattended vehicle" laws here in NC too, but only enforceable in public areas (gas stations, stores, etc.).....NOT in private driveways......
