How to remove computer
Old Nov 4, 2006 | 09:51 PM
pikiluvi's Avatar
pikiluvi
Question How to remove computer
1994 F-150 regular cab 4.9. Do anybody know how to remove the computer.
Also ; I pull a computer from a E-150 Van :
same year 1994
same engine 4.9
same tranny E4od
same rear end 8.8
Does anybody know if it will work on my truck? Thanks
Old Nov 4, 2006 | 10:06 PM
quicklook2's Avatar
quicklook2
the computer is below the brakes, a little closer to the fender.
they should if the numbers match.
Old Nov 5, 2006 | 07:15 PM
lostin90s's Avatar
lostin90s
loosen harness bolt then pull off harness loosen other bolt take fenderwell loose to remove or take out from inside (I've never done it that way) Should slide out. Good luck
__________________________________________
94 F150 XLT SC LB Maf 302 E4od
Old Nov 5, 2006 | 07:24 PM
quicklook2's Avatar
quicklook2
it does not come out from inside the cab.
it comes out in the engine compartment.
the inner fender is what needs to be loose.
Old Nov 6, 2006 | 09:52 AM
pikiluvi's Avatar
pikiluvi
Thumbs up Got it !
It came out thru the engine compartment. Yes; I had to loose the inner fender. Thanks
JBender
Aug 31, 2012 08:55 PM
SideWinder4.9l
Jan 12, 2010 11:27 PM
pikiluvi
Computer Chips & Tuners
Nov 6, 2006 04:49 PM
blueovalwonder
Jan 10, 2005 09:06 AM
GammaDriver
Mar 2, 2002 06:25 AM
