I have a 97 F350 PSD that I bought new and recently bought a 96 of the same. I noticed the 97 is rated at 225hp while the 96 is 215hp. Anyone know what International changed in those model years? Computer settings, internal parts, etc.? Also, if one were to use a tuner on both, such as the superchips, would the trucks have the same power afterwards or would the 97 retain a 10hp advantage?
you must have a california truck that has the split shot injectors in them. and the computer programming is a little differnt and has a differnt fuel pump and regulator setup. other than that its all the same. the 97 would still have more power.
jake - The 97 is not a CA truck, I bought it new off the lot in Virginia, December '97. The 96 was in Kansas its whole life until last month. There's a noticeable difference in the trucks. Neither truck has many miles on it.
cfpinz, My rig is a 97 and ist say's 225hp on the valve cover also. Hay barback is there a way to tell if it's cali. truck? I know mine is a utah rig. thanks.
