Shocks
Old Nov 4, 2006 | 05:02 PM
explorerford1999's Avatar
explorerford1999
Smile Shocks
Ok I know everyone likes the Bilstein Shocks but I would like input on other shocks that have been installed on Expeditions, such as Monroe Reflex, KYB Monomax or Gabriel Max Control. It seems that Monotube shocks are the way to go. Thanks
Old Nov 6, 2006 | 02:35 AM
Greenscobie86's Avatar
Greenscobie86
Id love to give you some advice but i have Bilsteins. Theyre great, and for $239 shipped you cant beat that! Id look no further than Bilsteins if I were you, unless you are on an extremely tight budget.
Old Nov 6, 2006 | 09:03 AM
explorerford1999
That's what I figured...
Old Nov 6, 2006 | 09:54 AM
afsigma21's Avatar
afsigma21
I got new Monroe Sensa Trac's put on this year, at 80k miles. I barely noticed any difference from the stock ones installed at the factory (Which were most likely bad). I do not recommend them. Although, it was only about $150 installled.
Old Nov 6, 2006 | 05:26 PM
mastiff's Avatar
mastiff
i went with the bilsteins, bought them online for around $260. They made a big difference. I highly recommend them.
Old Nov 7, 2006 | 07:33 AM
Johnny Langton's Avatar
Johnny Langton
I'm using the Reflex shocks on my personal F150, and the work truck F150. They're a good compromise shock for daily driving,and the handling and ride are both pretty good. I dunno how well they'd do on and Expy,but they should be about the same.
I'll most likely put Bilsteins on my Navigator when I replace them here in the near future.
JL
Old Nov 17, 2006 | 06:36 AM
verticalrich's Avatar
verticalrich
shocks are very easy to replace yourself
Old Nov 17, 2006 | 12:43 PM
dukman22's Avatar
dukman22
Expy99, I just in the last couple of days put a set of Pro Comp ES9000's on a 2000 4x4 EB with conventional coil spring suspension. It has 86K on it. They replaced a set of Monroe Sensatrac's. I don't know at what point they were installed, since I just bought the truck from a dealer.
Quite honestly I noticed a slight improvement, but not just a huge amount. There is still a bit too much body roll to suit me. The Pro Comps were a good price $106 shipped to me, so that had a certain attraction. At this point I have ordered a Hellwig sway bar to go on the rear and a Energy Suspension replacement bushing set for the front. I feel like this will be an acceptable combination. I will try to post my impressions when that is completed.
Old Nov 18, 2006 | 08:20 AM
Phil056's Avatar
Phil056
explorerford1999,I purchased and installed the Monroe Reflex shocks for my 98. They work great, not too soft/harsh on highway, they'll make a world of difference if your shocks are currently worn out.
I got mine at shockwarehouse.com
911133 Front
911145 Rear
Old Nov 18, 2006 | 01:48 PM
explorerford1999
911133 Front
911145 Rear
Thanks for the input, I know most people like Bilsteins but I'm not sure I want to spend that kind of money. Monroe's have a lifetime warranty and could be ordered locally.
Old Nov 19, 2006 | 06:59 PM
tsax's Avatar
tsax
I installed Bilsteins myself. Great shocks w/ the LLS.
Old Nov 22, 2006 | 10:55 AM
peter57's Avatar
peter57
Hi All,
I am going to replace my shocks with Bilsteins and others have mentioned a slight modification to the bushings for the front shocks, (to be able to start the nut). Does anyone have more info as to exactly what part of the bushing or how much is trimmed? Thanks!
Old Nov 26, 2006 | 09:20 AM
john_p's Avatar
john_p
guys is it possible to replace the oem shocks (air type w/ lls) with Bilsteins?
Old Nov 26, 2006 | 09:54 AM
aagitch's Avatar
aagitch
What kind of mileage are you guys looking at when it's time to change shocks? Not sure when I should start looking at that.
Old Feb 19, 2007 | 12:37 PM
explorerford1999
Talking
Well I finally made up my mind on what shocks to purchase. I bought Monroe Reflex from Auto Barn for $160 shipped. Installation was a breeze; just remove all four tires and not a problem. No modification need to get the shocks to fit. I have 90,000 on my Exp with the original shocks. One was leaking, two had no pressure and one seemed ok. The test drive- Truck rides awesome, no more noises, smooth and responsive.
