Rear Main
Old Nov 4, 2006 | 01:00 PM
bart6180's Avatar
bart6180
Rear Main
i have an 82 f-150, straight 6 with a manual 4 speed, my rear main seal went out so it's pissin oil, will it be easier to change by yanking the engine, or pullin the tranny, as i only have one day a week off of work to try fixin it, and i need to get it done before the snow flies
Old Nov 4, 2006 | 04:24 PM
ol'reliable's Avatar
ol'reliable
Hey, if you have the one piece seal, and being a six cylinder it should be as I recall, then the quickest way is to pull out the tranny. It is a lot more work to try and pull the engine, with exhaust, coolant, fuel, and wiring to deal with. If it is a two piece seal like the older 302 engines, then you need to drop the oil pan and put in a new gasket there as well. Again, I don't think that the 300 ci engine used a two piece seal, only a one piece.....
Old Nov 4, 2006 | 04:26 PM
ol'reliable
Also, if the crank is grooved you should be able to get a speedy sleeve, I am quite sure they are available with the one piece seal engines...
