Fuel delivery problems
Old Nov 4, 2006 | 11:25 AM
bombbill's Avatar
bombbill
My 89 5.8 liter main fuel pump is'nt getting power. I hooked up a wire directly to battery and it worked for awhile then quit again? Is the computer causeing this,and is ther a way to check computer to see if it has gone bad ? I bought a new truck and need to sell this one so I don't want to keep pouring money into it. HELP
Old Nov 4, 2006 | 11:59 AM
subford's Avatar
subford
No the computer does not normally cause this. If you hooked up a wire from the battery to the fuel pump and it does not run you have a bad pump or bad ground.[/QUOTE]You might also check the Inertia fuel shutoff switch for the problem of not getting power to the pump but would be out of the pitcher if you ran the wire.
