i have a 1977 ford ranchero with a 400 and i installed a holley commander 950
fuel injection and i also installed a msd 6
ingition box with a ford computer controlled disributor,and tfi module so the holley would control the timing my problem is the car wont start it just cranks
is there a base map for this engine i m using the 302stock map and all sensor are working . i think im not getting and spark so any help on that would be helpful
thanks
Welcome to FTE! This forum is for introducing yourself. Your best bet would be to click FORUMS at the top left then scroll down to the 400 engine forum. You will get some help there. Enjoy the site.
thanks
First thing first is the distributor. Just have to ask the obvious question, did you use the 460 distributor or the 302 distributor? The two have a different geard that run on the cam. The 400 uses the 460 distributor gear on the cam.
What part # do you have of the commander series? It should be long and start with a 9. I went to the holley site, and they have instructions there. But there are a lot of different commander systems. The one I picked was for a big block chevy, and required a crank trigger for the ignition.
It sounds like it's in the wiring. I would go back to Holley's instructions, and follow the wiring diagram found on page 101, figure 75. Double check the wiring if you've already done it. The instructions should have came with the system, or can be found here:
