starting issues
Old Nov 3, 2006 | 04:43 PM
Gman91's Avatar
Gman91
starting issues
94 f150 302v8. parked the truck last night , and everything was fine.go to start it this morning,the battery gauge was reading low and the truck wouldn't
start, not even the clicking noise from the starter. got home today and tried jumpstarting it, this didn't work, so i tried recarging the batter, still didn't work.put in a new battery and that didn't work. checked the fuses, and the connection to the starter, and cleaned all the connections on the cables etc.
any ideas on getting my truck running would be great.
-i am getting full power in te cab, lights, stereo etc.
Old Nov 3, 2006 | 06:49 PM
cdh1313's Avatar
cdh1313
I would check the starter solinoid relay, its the black box by the battery that the hot from your battery runs to.
Old Nov 7, 2006 | 02:07 PM
Gman91's Avatar
Gman91
replaced the selenoid, and got the truck running again. but now someting under the hood is whinning, and creating smoke( not clearly visible).any ideas as to what might be causing this?checked all the fluids, and everything got toped off.
Old Nov 9, 2006 | 03:16 PM
Gman91's Avatar
Gman91
got the truck running and found that the smoke was coming from the starter. replaced the starter, and still have the problem. then i hought it might be the selenoid, so i tried another now one, and it still dosen't work.As far as I can tell , the bendix is hooking up with the fly wheel, but it isn't coming back out.
Anybody got any ideas on how to fix this?
Old Dec 12, 2006 | 06:56 PM
hepennypacker's Avatar
hepennypacker
You should try shims on the starter first, then let us know if it worked.
