viberation
Old Nov 3, 2006 | 10:16 AM
ncfirefighter46's Avatar
ncfirefighter46
Question viberation
hey all, well i got a 79 f150 here the it vibrates real bad, when you are driving down the road but stops when you let off the gas, but it shacks so bad the truck feels like it is about to fall apart, now we have change all the firing componets, and when it is idling it dont miss you can give it gas in park no shaking? got me puzzled what could it be??
Old Nov 3, 2006 | 10:25 AM
LxMan1's Avatar
LxMan1
Bad u-joint? Differential about to come apart?
Is it an engine miss or something else in the drivetrain.
Old Nov 3, 2006 | 10:34 AM
75F350's Avatar
75F350
Crawl under, and check out the driveshaft for any movement at the u-joints. Make sure you inspect the trans mount as well. Could be broke, and letting the trans flop around.
Old Nov 3, 2006 | 10:54 AM
tommyrs33's Avatar
tommyrs33
Both are right. U-joints. Under power it will cause vibration if they are shot. Mounts could also well be loose.
