i drive an '05 ford f-150 xlt and i am going to level the front of my truck with the rear and was wondering how big of a tire can i put on the truck after it is leveled.
It depends on what truck you have. If you have the 2 wheel drive then 33 X 12.50 on the stock wheels is the largest. If you have the 4 wheel drive then 35 X12.50 on the stock wheels will fit. If you go with aftermarket wheels then it depends on the back spacing.
if you put the 35" tires on a level'd 4x4 you will be sorry. yes the tires do fit without rubbing...when level anyways. the second you go over a bump or drive down a dirt road, you're going to hear them rubbing. the 33" tire is looks really nice on these trucks and leave sufficient room for suspension flex.
yes, looks great and plenty of room to stuff the tires in the wheel well if you go offroading.
make sure there is enough backspace if you're using the factory rims. a good tire shop will be able to steer you to the best set of rims you'll need if your current rims don't have enough backspace for the 12.5...I'm pretty sure they'll work fine though
do a forum search. quite a few people have already put 33"s on their trucks and they posted the exact size (10 or 12 or 12.5 I can't remember) that they're running right now
