Wouldn't shut off
Old Nov 2, 2006 | 08:34 PM
tuke's Avatar
tuke
Wouldn't shut off
I got to work tonight and shut the ignition off and removed the key but the truck kept on running. Everything else shut off radio gauges etc.. Put key back in and in KOEO position and everything looked normal ,what to start, radio glowplugs cycling. But still running. Tried to turen it off/on a few times and it finally shut down. I tried to start it and it fired right up and then I shut it down with no problems. I just hope it starts at 3 am when its time to go home. The ign. switch is fairly new. Any ideas? Thanks Ed
Old Nov 2, 2006 | 10:03 PM
CheaperJeeper's Avatar
CheaperJeeper
Sounds like maybe the fuel cutoff solenoid in your IP is sticking open...
Old Nov 2, 2006 | 10:33 PM
yamaguy's Avatar
yamaguy
I agree with cheaperjeeper on the solenoid possibly being the problem. I used to have a Mostly Old Parts And Rivets with a Cummins in it and it did the same thing a couple of months before the ip blew! Not saying that the navi will do the same, but don't go to the other side of the country with it like I did till you check it out.
