Sponsored by: Real Truck
Tire Size
Old Nov 2, 2006 | 01:31 PM
ccerniglia's Avatar
ccerniglia
Tire Size
Guys, Just want to know that are the largest tires i can fit on my Stock Rims (16"x7") without a Lift. Also with out any rubbing of course. Thanks.
Old Nov 2, 2006 | 01:48 PM
Autobahn F-250 Lariat's Avatar
Thumbs up
Welcome to FTE
285/75/16 safe bet
though guys have ran 295's and also 305's depends on brand not all tires are created equally
Old Nov 2, 2006 | 03:24 PM
Zip's Avatar
Zip
I run a 285/75/16 on mine. I don't think that anything bigger would fit. They seem to be quite tight at the rear of the front tires.
Old Nov 2, 2006 | 03:54 PM
akford351's Avatar
akford351
I agree w/ the above... 285s
Old Nov 2, 2006 | 04:12 PM
Enomra's Avatar
Enomra
my 2006 King ranch came with 20" wheels and it has 285 65 R 20 wich is 34.6" tall and there is no clearance issues with them. The 20" wheels are an option on the King Ranch. I think if you stay with a 285 series tire you can easily go to 34" with out a problem. They are just hard to find. You will run into problems with the wide tires.
Old Nov 2, 2006 | 07:43 PM
TwelveAlpha's Avatar
TwelveAlpha
I agree on the 285 75 16, it's what I have for a couple weeks more yet, and I used to say they didn't rub, but apparently, on occasion, I'm contacting the plastic inside the fender.
I also think *operative word* that the older body style like mine - 01 - has a little less room than the newer.
Old Nov 2, 2006 | 07:54 PM
jake00's Avatar
jake00
you also have a different suspension up front, the pre 05's have less clearance up front
Old Nov 3, 2006 | 08:36 AM
Enomra's Avatar
Enomra
Correct the new suspension is a coil. On my 1999 SD I ran 315 75 R16 (35)on it stock for a few weeks while my leveling kit was shipping to me. They did have clearance problems. The issue is not in height as much as it is width Les Schwab sells a 255 85 R16 which is over 33" tall. I know someone who runs those and chains on all four tires durring the winter on a stock 2000 with the 7.3 diesel. I think you can run a 35" as long as the section width is under the 285mm.
