i have 94 ranger 5 speed 2.3 liter. engine races like the throttle is stuck. but problems is not the throttle body. i took it to advance atue and they put a code reader on it. don't know the code numbers but all sensors ie.(maf,map,erg tps,etc) all said voltage exceeds maximum. any help will be appreciated
thanks
blaise77777
So you have a check engine light on?
If you didn't, I would say IAF, as you do, I would check the output of the alternator. If it has a problem, and the engine is racing it to put out more voltage....
If you have a CEL there is no way to diagnose it correctly without getting the code(s). Anything else is guessing. You can go to most autoparts stores and they will pull the codes for you free.
