fuel line problem
Old Nov 1, 2006 | 05:44 PM
1987fi50's Avatar
1987fi50
fuel line problem
i recently took the fuel injection system off the intake manifold because i was switching the entire system over to another engine. i was in a hurry while doing this and instead of figuring out the best way to unhook the fuel injection system, i just cut the line that leads out of the system. now because of my retarded decision, i have to figure out a way to reconnect the two lines. does anyone have any ideas? anything will help
thanks
Old Nov 1, 2006 | 07:01 PM
Franklin2's Avatar
Franklin2
See if lowe's has a compression fitting (coupler) that will fit. I can't remember if it's metric or not, but 8mm is the same as 5/16" anyway. Some of the others are close, but there are a few that will not crossover.
If you find a brass compression fitting that will work, make sure it has the little brass inserts that fit inside the plastic tubing(fuel line). If you do not use these, the compression ring will just collapse the plastic tubing and not hold.
Old Nov 10, 2006 | 11:32 PM
theman79's Avatar
theman79
car quest usually has a lot of fittings that will help you out
