1978 - 1996 Big Bronco
90 Bronco Fuel System Problems
Old Nov 1, 2006 | 07:27 AM
lespauljr2005's Avatar
lespauljr2005
Hello All,
I have a 90 Bronco 5.8L E4OD that is driving me nuts. Fuel pump in the tank whines like hell sometimes then other times no noise at all. I changed the fuel filter, added tank/injector cleaner so far and same results. Also when it starts up it idles up to 900. then drops to like 550 in like 5 seconds. I put into reverse then it stalls and surges like the transmission is out of wack. This only happens sometimes and no constant thing like only in cold weather,etc.
No check engine light ever came up on dash.
No parts have been changed on this fuel system,only the lines from what I can see.
Your ideas and comments would be much appreciated.
Thanks, LesPaulJr2005
Old Nov 1, 2006 | 10:22 AM
Kemicalburns's Avatar
Kemicalburns
pull codes, even with no CEL a code can still be stored . www.fordfuelinjection.com will show you how using a paperclip.
Old Nov 1, 2006 | 02:27 PM
dwoodler's Avatar
dwoodler
The idle problem could be timing (spark) instead of fuel....have you checked it?
Old Nov 1, 2006 | 04:21 PM
lespauljr2005
Thanks for the info, I'll work on the code stuff. For Timing? New cap and rotor 1month old. Plugs and wires 2years ago approx10,000 miles on them.
