Auto Temperature Switch Question
Old Nov 1, 2006 | 07:16 AM
Big-Red-Lariat's Avatar
Big-Red-Lariat
I received my truck in the Spring, and outside temps have always been above freezing till now, When I start the climate control auto temp with the temperature setting at max heat degrees, I see the AC light come on every time, and I have to then push the small rectangular AC switch to turn off the AC.
Is this normal?
Shouldn't this "auto temp" system know that it is cold outside, and go straight into heater mode right away?
Can someone try it on theirs and let me know what happens? Thanks.
Old Nov 1, 2006 | 07:29 AM
4DOORSR's Avatar
4DOORSR
Same thing happens on my 04....
Old Nov 1, 2006 | 07:39 AM
Big-Red-Lariat
YA BUT WHY? dOESNT MAKE ANY SENSE 2ME.
Old Nov 1, 2006 | 10:08 AM
sysman_rick's Avatar
sysman_rick
The operative words are auto climate control. Depending on what the previous settings/environment were prior to entering auto climate control the unit will do cycle/switch heating/cooling commands.
Old Nov 1, 2006 | 10:15 AM
screwy's Avatar
screwy
It’s by design. It doesn’t use the AC for cooling in the winter but rather as a dehumidifier to pull the moister out of the air so it doesn’t freeze to your windows. It’s probably only running the compressor at 1/4 or so of what it would in the summer. They’ve been doing it for years, just have a little light to tip you off now.
Old Nov 1, 2006 | 02:13 PM
Big-Red-Lariat
5.4 uses enough gas...annoying to have it run AC to heat the vehicle & use more!
My grandfather always used to say "damned contraptions!!"
Old Nov 1, 2006 | 02:32 PM
screwy's Avatar
screwy
Well if it bothers you, I know on my truck if you turn it to floor the ac wont run, but mines a little older and not automated. Another option is to just unplug the AC clutch, but that may throw a code and you’ll probably be plugging it back in when your windows frost over on the inside.
Old Nov 1, 2006 | 10:03 PM
the4by4freek's Avatar
the4by4freek
The new Electronic climate control is much smarter than you think. It actually senses the coolant temp and will not turn the heat on until the coolant is warm enough to actually blow heat. The AC light is just as stated above. The last function that was performed will illuminate on the display. It doesn't make any difference if the AC is on or not. The compressor still cycles on every mode except vent. All the Fords have been like this for the past 10-11 yrs. My Taurus does it, My Ranger did it, My Expedition did it, the F-150, and 250 do it. My wifes Dodge that she had did it too. The compressor does as stated above... it pulls the humidity out of the vehicle
Old Nov 2, 2006 | 07:35 AM
Big-Red-Lariat
agreed, but if i set it to auto and turn up the desired temp. to max., it should start the blower when the engine is hot, right? It just sits there saying "AC". If you finally want heat, you have to start the fan with the dash or steering wheel manual fan control.
My 03 Lariat used to do what you described, and also if someone opened the door on a cold day, it would increase the blower speed automatically until cabin was warm again.
The 06 isnt doing it, so do I have a problem, or a feature change here??
Old Nov 2, 2006 | 05:17 PM
the4by4freek
If you shut off the AC light by pressing the button does it blow heat? If not then I would say you have a problem somewhere in the system. It might be a change for 06 also. If the AC is selected and the desired temp is at or below the temp in the truck it will not do anything. I would check the manual on that one and see what it says about it. I did not drive my truck today so I cannot check it tonight. By the time I get out of work everyone will be asleep.
Old Nov 2, 2006 | 09:19 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
the auto temp thing is very sensitive. mine gets to the dialed temp quickly and stops. periodically it will kick on and heat/cool as needed.
my A/C also sporadically kicks itself on as well. I turn it off as soon as I notice it, but the truck is still blowing hot air while the A/C light is on.
the only time I ever actually hear the fans running is when it is <35F outside and the windows are fogging up, or if someone gets into the truck after it got to the dialed temp
Old Nov 3, 2006 | 08:14 AM
Big-Red-Lariat
yes, I can make it blow heat if I turn up the fan manually, but I thought the auto switch was supposed to do that automatically as it did in my 2003.
It was working fine keeping the AC constant during summer heat.
Design change, or a bad sensor, or a bad switch ???
Where's that FORD guy who hangs around the forum and seems to know everything? (said in good complimentary context ;-) )
97ExpGuy
Jun 4, 2009 08:47 PM
swilson
Jun 22, 2008 05:58 AM
conger
Mar 19, 2007 04:49 PM
myjaycopuller
Jul 14, 2004 02:47 PM
