Driving Blind!
Old Oct 31, 2006 | 09:16 PM
MarkoSephano's Avatar
MarkoSephano
Driving Blind!
I recently bought a 1986 F150, and I love it!! Problem is this, now that the daylight savings time is over, I am driving home after dark, and maybe the instrument panels on these older trucks were never too bright, but I am having one heck of a time reading the gauges! And yeah- I turned the headlight **** left and right to get the the panel lights to shine their brightest. There doesn't seem to be any obvious dark spots (like a individual bulb is out) it is just uniformly pretty dim, and everything else shines bright (headlights etc., so I don't think it is the battery). Any takers?
Old Oct 31, 2006 | 09:29 PM
WA1986F-250's Avatar
WA1986F-250
It's not you. The backlighting on that cluster is pretty dim. The light isn't very bright. It doesn't help that the background is black. I've been meaning to pull my cluster out and reverse the colors. White background and black numbers.
I drive alot at night, so this gets pretty annoying, especially when my eyes get used to the lights from oncoming traffic.
Old Oct 31, 2006 | 09:30 PM
Old Rust Bucket's Avatar
Old Rust Bucket
What I did was I put a little light bulb that shines into the dash. I then put it on a toggle. Of course you could pull the whole dash off and try new bulbs. Not sure if you could get at the bulbs from behind or not. I have an 83 F150 and IMO the dash lights leave alot to be desired. I wonder if there are replacements avialible that are brighter then the originals. I'll have to look into it.
Old Oct 31, 2006 | 10:10 PM
MarkoSephano
Wow! Thank Guys! I really appreciate your advice. I may have to do some sort of modification myself! Maybe strap a flashlight on my ballcap!
Old Oct 31, 2006 | 11:24 PM
Old Rust Bucket
What I did was get an interior light (the ones under the dash) out of a Late 80's GM pickup. It has a shield around three sides so it only shines in one direction. I just drilled a small hole in the dash right next to the steering column and screwwed it on. In my case I wired it into the the radio wiring. I was too lazy to trace the wires from the key switch but it would be better to do it that way. The light is too bright to leave on all the time. Basicly flip the toggle for a quick glance then shut it off when you no longer are looking at it. It is about equivelant to a D cell Maglite. Just be sure to play with the light first before you start drilling holes. Make sure you got it where you want it. I find that it works best if it is pointed at the center of the dash.
Old Oct 31, 2006 | 11:42 PM
Piffery1's Avatar
Piffery1
Pull the cluster, remove the gauges, remove the little blue plastic covers over the bulbs, replace the existing clear bulbs with blue or green versions then reassemble everything. While you're at it replace the turn and high beam bulbs with new clear long life bulbs.
Old Oct 31, 2006 | 11:52 PM
Old Rust Bucket
Where would I find these? Napa?
Old Nov 1, 2006 | 01:33 AM
Piffery1's Avatar
Piffery1
I got the long life ones at Walmart and the colored ones at Advance, I think (or vice versa). Colored ones are #194G for green, #194R for red, etc. Don't remember how the long life ones are numbered but it says on package "Long Life", "Extended Life" or something akin to that. There are also some high brightness white and amber LED's that are replacements for #194's which would may be good for turn indicators, etc. but not for instrument panel illumination (they probably won't dim properly). I've seen the amber LED's locally but the whites only on eBay. NAPA, AutoZone, & O'Reilly's may also have them. You can also paint the inside of the cluster with Aluminum or Chrome metallic paint for plastic models to increase the reflectivity for the indirect lighting. Just don't get any of the paint on the Cluster printed wiring.
Old Nov 1, 2006 | 07:17 AM
MarkoSephano
Thanks Piffery 1, I am going to take care of this this weekend! I appreciate the wisdom!
Old Nov 1, 2006 | 09:08 AM
Sycostang67's Avatar
Sycostang67
I did this except I still use regular clear bulbs, the 194LL are the long life bulbs. It is still very easy to see, certainly much better than it was. I have done this to my wifes car as well.
Old Nov 1, 2006 | 05:38 PM
hoxiii's Avatar
hoxiii
The green dashlights are actually pretty bright if your electrical system is up to snuff. I kept trying things like auxilliary lights, but what finally solved the problem was when my alternator went out.
I replaced the alternator, voltage regulator, and redid the alternator to solenoid wiring harness. Now my dashlights are as bright as I'll ever need them to be, it charges more consistenly, the headlights are brighter, and it eased up the ford flickering headlight syndrome. (that finally got solved by a set of relays)
Justin
Old Nov 1, 2006 | 06:18 PM
MarkoSephano
How many bulbs illuminate the instruments, anyway? I would like to go ahead and buy the bulbs prior to tearing into the dash. It is my only transportation, and it would just go a little more smoothly if I had them on hand. Thanks Guys.
Old Nov 1, 2006 | 06:54 PM
1987_f150's Avatar
1987_f150
Just goto advanced auto and get the tiny led lights.
82F100SWB's Avatar
82F100SWB
This is what you get with all new bulbs, nice clean connections, and a good charging system:
I don't recall exactly how many bulbs are in the cluster... I'll have to dig up one of my spares.
Old Nov 1, 2006 | 08:34 PM
Piffery1's Avatar
Piffery1
Five in the instrument panel plus one in the windshield wiper/ headlamp switch area, if I remember correctly. Not counting turn, high beam, etc.
