main bearings
Old Oct 31, 2006 | 01:28 PM
Rodneyt444's Avatar
Rodneyt444
main bearings
I am rebuilding an 88 2.9 motor and got new main bearings and the thrush bearing is not the correct one. I bruoght the old bearings to the parts store they called federal mogul and matched the numbers and said this is the right set for the motor but clearly if the thrush bearing doesnt fit around the crank it cant be right.Crank has never been turned and it has original ford bearings. Is there a special bearing set for this motor.Numbers on old main bearings 73TM6333AA and on the thrush 73TM6337AA and on the new ones 3056RA and on thrush 3057 RA federal mogul part # 6101 M. Are they giving me the correct set.
Thanks Rodney
Old Nov 1, 2006 | 07:13 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
To find out where to ask this question, click on this link
https://www.ford-trucks.com/forums/s...88#post3272088
See you on the boards. ….
AFordMan
New Member Introductions
Feb 14, 2007 04:19 PM
sileran
Dec 23, 2006 07:50 AM
Monster Tech Inc.
Nov 6, 2006 02:12 PM
AMANDA75
Sep 28, 2006 05:18 PM
GLRIZZ
Jul 13, 2006 02:22 PM
