Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
fish tape
Old Oct 31, 2006 | 12:44 PM
karlg's Avatar
karlg
fish tape
I'm trying to "push" my fishtape through the buried conduit between my house and detached garage and can't get it through. Conduit is 1inch PVC and about 45 feet and fishtape is 1/8inch steel. I can get the tape most of the way and then it stops. I've tried going from both directions(I'm going to pull a phone line and a coax cable so direction isn't that critical). I ran all of the conduit except the run through the garage footing and the slab(that was done by the concrete contractor). I used sweeping el's and cleaned up my cuts. Suggestions??
Old Oct 31, 2006 | 01:22 PM
Ultraute's Avatar
Ultraute
Is your fishtape rusty? A rusty tape will have trouble with even two ells. How many bends in the run, total?
Does the fishtape stop at about the same spot from either end? Could be there is something in the pipe, or it came appart.
Try to suck a light string thru with a vaccum cleaner, then use the string to pull thru a small rope (1/4"). Use the rope to pull the wires.
Old Oct 31, 2006 | 02:31 PM
bigrigfixer's Avatar
bigrigfixer
The Pacifier
Our phone and cable guys had the same problem hooking up our new house. They tried everything. Vacuum and string, smoke machine, they even had me stick my head in the access hole only to get distracted by one of my hot neighbours. What they ended up doing was getting out the big sucker, a 3/8" fiberglass fish.
Old Oct 31, 2006 | 02:32 PM
karlg's Avatar
karlg
Fishtape is pretty new, no rust. I used 3 bends in my run. I'm hoping the concrete contractor only used one sweeping bend through the floor and footing. But I have no idea. No, fishtape doesn't stop at the same spot when I come at it from either end. So...it doesn't seem like there is something in the conduit. The tape moves pretty easy and then just stops. Happens from either end. Maybe the number of bends and the distance is enough that I cannot push the end of the tape past the edge of a fitting?? If the conduit had come apart, wouldn't you expect it to be wet and muddy? We have had a lot of rain lately. Might have to try the string and vac trick. Thanks.
Old Oct 31, 2006 | 02:39 PM
karlg's Avatar
karlg
Interesting. Any idea why the bigger tape worked better than the smaller?? Better to get past fitting edges? Can get more leverage behind it?
Thanks, Karl
Old Oct 31, 2006 | 02:48 PM
bigrigfixer
The Pacifier
I think what it was, was the original cable guy came with an 1/8" fish and it went out 100' but he couldn't find it out the other end which was only 80' away. He tried a few times, sometimes only able to go 50', then he came and got me to help him. Then I saw something move as I got distracted, and couldn't see it again. There wasn't really any kinks or signs of snagging on it, maybe just operator error. So the next day, the supervisor comes out with the big one, and gets it done in less than a minute. I guess he was able to get more force on it with the bigger one.
Old Oct 31, 2006 | 04:06 PM
tjc transport's Avatar
tjc transport
i ain't rite
i ty a piece of string to a piece of foam the size of the pipe and use compressed air to blow it through.
Old Oct 31, 2006 | 05:47 PM
Greg 79 f150's Avatar
Greg 79 f150
This takes two people. Run your fish tape in until it stops. Borrow another fishtape and go to the opposite end of the conduit and push it thru until you feel it hit the other tape. Push this 2nd tape in past the first tape about 3-4 feet then roll the 2nd tape reel over and over 4 times or so....
This will wrap the 2nd tape around the one already in the conduit. Pull back on the 2nd tape slowly while your helper pushes slightly on the first that was put in. The 2nd tape will pull the first tape passed the fitting and come on out. I have done this many times on 60-80 foot runs where the FT stopped.
PS Hopefully when the concrete ws poured they sealed your stub up conduit good. Nothing will pass thru a hunk of concrete very well. good luck
Old Oct 31, 2006 | 07:19 PM
643NRK's Avatar
643NRK
You said it pushes easily and them stops. Does it seem to go about the same distance from either side? You said you used 3 bends in your run, were they less than or equal to 90 degrees each? Does the number of bends in your conduit include the one that the contractor put through the slab? The general rule of thumb is to not put more than 360 degrees of bend between pull points, this makes pulling cable much easier. The double tape trick described above will work, just be sure not to get your tapes stuck. Good Luck
Old Oct 31, 2006 | 09:34 PM
bas157's Avatar
bas157
And once you do get the tape all the way through, pull a few extra pieces of heavy string (rope?) through with the phone and coax.
that'll make it easier if you need to run something else in the future.
Old Oct 31, 2006 | 10:07 PM
Torque1st's Avatar
Torque1st
Posting Legend
Braided nylon cord works well, tie it to something at each end. If you use it remember to pull a new piece thru. I have one run at the house that has 2X the length of the run in it tied at both ends with a small loop tied at the center of the cord with the excess coiled at one end. I can tie a wire to that loop and pull it to the other end then pull the loop back.
Old Nov 6, 2006 | 12:02 PM
karlg's Avatar
karlg
Just wanted to thank everyone for their suggestions. Looks like I had one too many bends to push my tape through. I tried the string trick first. Didn't want to get two tapes stuck in the conduit. My shopvac sucked the string through without a problem. I have my phone line and coax into the garage now. Thanks again. Karl
Old Nov 7, 2006 | 12:08 PM
Timca's Avatar
Timca
We've used a sandwich baggie tied to a piece of jet line (small String) and a shop-vac and sucked line as much as 500 feet. Glad to see you got the problem solved. Tim
