code readers
Old Oct 31, 2006 | 11:44 AM
unger316's Avatar
unger316
code readers
i'm looking at a code reader for my 87 f150 and i was wondering what should i get. Are cheap ones worth it or should i spend more and get a name brand
Old Nov 6, 2006 | 07:16 AM
straightexhaust's Avatar
straightexhaust
dont mean to hijack this but i have a 1989 f250 and i too am looking for a code reader.
Old Nov 6, 2006 | 07:54 AM
kbolk's Avatar
kbolk
Tell U what! Both of you give me $20.00 and I'll read your codes.......teeheehe
Old Nov 6, 2006 | 01:18 PM
straightexhaust
aaaaa...no thanks...
Old Nov 6, 2006 | 05:35 PM
Cheggie's Avatar
Cheggie
For fuel injected F-150's up to and including most 1995, you don't need a code reader. They work fine, but a paperclip and the check engine light will do exactly the same thing. You need a Haynes manual (About $17.00) because this will detail the "paperclip" procedure and tell you a little bit about what to do once you get the codes. The codes will help you, but they will not do all the diagnostic work for you. There are also several diagnostic modes to use, key on engine off, key on engine running, cylinder balance for those with sequential EFI, etc.
Basically, you use a paperclip to jumper the black and gray diagnostic connectors under the hood. You really need to see the diagram and follow the procedures outlined in the repair manual for this to work. When you set it up right, the check engine light will blink the codes out for you. There is a sequence, so once again, get the book first, and leave the OBD I code readers on the shelf. They're not necessary.
Old Nov 6, 2006 | 07:48 PM
kbolk's Avatar
kbolk
What do u mean n-n-not ne-ne-ne,,ne-ne,,...nessasary? Theye make me look cool, like I have some scientific deploma.... Geeeez ....The nerve of some people.....Not nessasary pheeee
spudlicker
17
Sep 28, 2016 08:36 AM
bkuuz1
Jan 11, 2010 12:02 AM
Dependable
Aug 22, 2006 10:50 PM
BodegaErik
Jul 2, 2006 02:41 AM
silvapain
3.0L V6
Nov 24, 2003 11:18 AM
