Sponsored by: Kumho
Flat-Spotting
Old Oct 30, 2006 | 07:40 PM
71LTD390's Avatar
71LTD390
Flat-Spotting
I have a '78 F250 with the original tires. Problem is that they are bias ply and flat spot like crazy. It took 30 miles of shaky driving this weekend for the truck to smooth out.
Question is: Is there anything that I can do besides blocking the truck up to keep this from happening. Truck will probably sit until next spring. Are there any pads, etc. I can put under the tires? Thanks.
Old Oct 31, 2006 | 01:31 AM
06fx4's Avatar
06fx4
make sure there always full of air dont know if it will stop the flat spotting but it will definatly help... but then agian if your gunna go out there and check the air pressure might as well roll it 3 inches
blockin it is the best way
josh
Old Oct 31, 2006 | 10:45 PM
tiredlr's Avatar
tiredlr
The problem with your bias ply tires is they are constructed from nylon cord.The nylon will flat spot when the vehicle sits for any length of time, worse when it's cold.They will eventually even out during normal driving, but the colder it is, and the longer they have sat, the longer it will take to round them out. The solution would be switch to a radial tire or jack the truck up off the tires, when parked
