headlight wires?
Old Oct 20, 2002 | 05:18 PM
Gwilkrrs's Avatar
Gwilkrrs
headlight wires?
the wires that mount to the metal block screwed to the rad support that go to the headlights. does that block need to be grounded to the metal support, or can they be relocated elsewhere?
Old Oct 21, 2002 | 11:58 AM
51f1's Avatar
51f1
headlight wires?
Don't know if this will help, or not:
Headlights:
Upper Center pole--Low Beam
Right pole--High Beam
Left pole--Ground to chassis or frame (If you are unsure the ground is good, it should have the same effect as the negative battery post)
Old Oct 21, 2002 | 04:59 PM
Kenny's Avatar
Kenny
headlight wires?
73FOMO
Aug 14, 2014 03:11 PM
CT
Ford Truck Parts for Sale
Nov 30, 2012 09:08 PM
frogmun's 55
Oct 29, 2009 11:52 AM
CAPTAIN
Feb 18, 2009 12:38 AM
jaye
Jul 7, 2008 09:59 AM
