Sponsored by: Real Truck
computer code for 06 f250 psd
Old Oct 30, 2006 | 06:30 PM
reefman's Avatar
reefman
I wanted to order an sct programmer from Troyer Performance this morning to take advantage of their group discount they have going until tomorrow, but I can't find my computer code anywhere!? On their site, it says to look on the drivers side door frame by the hinges, but there's nothing there. I tried looking everywhere I could think of, but still nothing. I need some help from anyone that knows, because I'm here on the west coast, but they're on the east and I'm not really able to call them in the middle of the day. Any help would be greatly appriciated, thanks!
Old Oct 30, 2006 | 08:20 PM
ReAX's Avatar
ReAX
It should have been a colored sticker near the windshield, mostly on the cab side. It is just a sticker and they do come off. The sure bet (if 06 is the same as 97-03)is to pop the hood, use a 10mm socket to disconnect the PCM harness. Then pull the drivers side kick panel, I can't remember if it's 2 or 3 bolts with 7 or 8mm heads, but pull those so you can remove the PCM. On the PCM there will be a 3 or 4 digit code, usually 3 letters and a number.
Old Oct 31, 2006 | 03:35 PM
cdkell's Avatar
cdkell
pop the hood, look on the passenger side cowl under the windshield you will see a wiring harness with three plugs that is the ECM the sticker is printed on it. hope this helps.
