i replaced the stock injectors in my 1997 Powerstroke with injectors out of a 1999-2003 powerstroke. those are the split shot type. i have now noticed that the EGT's are about 200-300 degrees hotter than before. what could i do to lower the EGT's that wont cost a fortune?
where can i buy a 3 inch stainless steel down pipe?
i also noticed that the trans is shifting much harder and the trans temp. gets hot quick. it wants to climb past 250 degrees. does anyone know what might cause this?
how much boost can you put out of the stock turbo on a 1997 Powerstroke?
i have heard that if you go over 42-44 PSI that you will lift the heads off of the motor. is this true?
A non stainless DP will be cheaper and will lower the EGT's. The site sponsors at the top of ht e page will have the DP you're lloking for.
YOu new found power in the engine is heating-up the tranny. Get a bigger tranny cooler at least. A custom chip will help the tranny too.
Yep, The turbo is capable of 40+ psi but a stock MAP sensor and PCM won't let you get that high but should'nt blow the heads off. There are a few guys on this site running higher boost #'s. Maybe they'll jump in here and fill you in.
the trans doesnt feel like it is slipping. are the torque converters known to go bad? the boost in my truck is about 32 PSI with the Edge Evolution. thanks for the information
Didn't the 97 CA truck come with 130cc injectors? I would do some research on how ford set that truck up to handle the added fuel. (custom burn)...just a thought. Might be cheaper but maybe not as effective.
