Sponsored by: Real Truck
Rear Diff question
Old Oct 29, 2006 | 10:17 PM
NeuralMonk's Avatar
NeuralMonk
Rear Diff question
Okay, I have a 99 F350 Crew Cab with 8' bed, 4x4, PSD, and 6spd. It is not a dually. It has the D1 differential (3.73 LS) in the back.
I jacked the truck up to work on the parking brakes and tried to spin the tires with the tranny in neutral and the transfer case in neutral. Mind you the entire axle and wheels where up and for the life of me, I had a hard time spinning those tires. There was no emergency braking at the time (because that is what I was adjusting to get some).
I jacked up the front and even with the hubs locked, these spun free.
Is this just the Limited Slip or drive train or is there a maintence problem here?
I would just think that this would be a bit easier to turn because the easier they are to turn the less heat I generate and less hp is robbed from the truck.
Thanks.
Old Oct 29, 2006 | 11:47 PM
John311t's Avatar
John311t
It shouldnt be too hard to turn. Try to d/c your driveshaft and spin it, it should spin pretty easily. Even though it is LS is should spin relativly easy.
Old Oct 30, 2006 | 01:12 AM
Matts72's Avatar
Matts72
Being the limited slip, you are turning against compressed clutches in the carrier that are normally not compressed while driving...
Try driving it a few blocks when cold, if its hot or the oil doesn't smell rancid you have a problem.
Old Oct 30, 2006 | 11:48 AM
NeuralMonk's Avatar
NeuralMonk
It could be that it was cold. I didn't really drive it much before testing it. I will check it after a drive.
Thanks.
torquemeister
Dec 12, 2013 12:16 PM
BEAL73
1997 - 2003 F150
Jul 3, 2012 10:22 AM
66 BADBOY
Modular V10 (6.8l)
16
Dec 10, 2010 01:03 PM
wolfrace
Apr 27, 2010 11:44 PM
kittyhawksurf
Jul 2, 2009 07:47 AM
