pabs compression update.
Old Oct 29, 2006 | 07:38 PM
pabs's Avatar
pabs
Thumbs up pabs compression update.
hey guys it finally runnig lots of power.But now there is a tinkling sound from valve train?What could it be and is it harmfull?Weird before replaced spring no tinkle tinkle now theres a tinkle tinkle any ideas guys.
Thanks for all the help guy.
Old Oct 29, 2006 | 11:39 PM
Spectramac's Avatar
Spectramac
Tinkling sounds are usually not good. Means somethings getting beat up somewhere. Any missing pieces you couldn't find on re-assembly?
Old Oct 29, 2006 | 11:45 PM
pabs's Avatar
pabs
no no missing pieces.Very confused.Nthing befor and tinkling after.Maybe wrong valve spring?Truck runs very strong and not much blue smoke.they say there are two type of valve springs rotunda and normal.The one i pulled had a white strip on it and one of the new ones had the same stripe so thats the one i put in.Any ideas.
Thanks
Old Oct 30, 2006 | 07:42 PM
Dave Sponaugle's Avatar
Dave Sponaugle
My bet is leaning toward something binding or loose causing slack between the pushrod and rocker. That is the only metal light enough to make a tinkle sound.
Old Oct 30, 2006 | 08:46 PM
bc6.9's Avatar
bc6.9
Pabs, I sent you an email, but I forgot to include the type of "diesel additive" I use...
Howes [I think thats how you spell it] & Diesel Kleen...haven't found a real difference between the two. The secret, I belive, is to add it with every fill up, in fact Dave S. fills his fuel filter with a diesel additive every time he changes it, good advice, I think. I have also used Duralube Fuel Additive...real cheap at Real Canadian Superstore.
Old Oct 30, 2006 | 09:46 PM
pabs's Avatar
pabs
Thanks i was a looking at aditives today.What oil should i run?Also what could i do or use to flush the engine oil?
thanks guys
pabs
Old Oct 30, 2006 | 09:58 PM
Spectramac's Avatar
Spectramac
Can you tell where the noise is coming from? Better pull the cover back off and check it out. Did that engine have the aluminum bridges between the rockers? They are pretty common to break if you tighten them down wrong.
Old Oct 30, 2006 | 10:10 PM
pabs's Avatar
pabs
Yes spectramac it does have the valve spacer or bracket.I'll have to see what happen.Noise is coming from pass side under valve cover it seems.
Thanks
Pabs
Old Nov 3, 2006 | 09:32 AM
pabs's Avatar
pabs
Talking tinkle tinkle gone.
hey guys i got the noise out of it.Runs and sounds well.but now it needs alternator and maybe a thermostat.Which one to get o.e.m thermostat or after marker.
Old Nov 3, 2006 | 11:00 AM
Spectramac's Avatar
Spectramac
So what was it? Or did you just floor it till it went away?
Old Nov 3, 2006 | 08:32 PM
Dave Sponaugle
The thermostat has to come from either Ford or International, the others are problems waiting for a place to happen.
I am also wondering, what was the tinkle sound?
Old Nov 3, 2006 | 09:19 PM
Spectramac's Avatar
Spectramac
Actually, the factory ford stats are rather problematic in my book. They have that rubber seal that tends to fall off and get stuck in the valve, holding it open. I used to change them out all the time and just throw one from Napa back in. Never had any problems with them. I went down to a 180* also and I can drive through the desert in over 100 degree heat with the camper and boat with my AC cranked.
Old Nov 3, 2006 | 10:23 PM
pabs's Avatar
pabs
Talking
hey guy sorry it took so long to get back.O.K dont laugh the tinkling noise was rubber exhaust mount with tin case case was rattling on stud.I feel like a idoit.The thermostat was stuck open and the alt was bad so im into the truck for $2400 What do you think of the new royal purple oil?Or should i stay with domestic oil?Truck runs well lots of power.
