Lever on IP, drivers side.
When I move this at idle, the engine smooths out and quiets down without changing speed. I suspect pump timing. If so, does this give an indication that my base timing is incorrect?
Thanks,
Jason
Plunger moving in (as I recall but I might be backward) will retard your timing. I wanted to advance my timing, so I carefully turned the set screw on the lever out (lefty) one eighth turn.
Driving my vehicle after that, it had noticeably more snap and rev over 2800 RPM. I wrote that all down in case it didn't work out but I'm recalling this from memory now.
It's a quick way to give yourself a little advance, just keep track of what you're doing and only turn the set screw a little bit.
Bruce
