6.9 blowing smoke
What things should I look at first?
Again, no offence intended bc6.9, and I'm not trying to single you out, or call you out or anything like that, because it isn't just you. There are a number of people on the board here who often make the same recommendation.
I understand that the pumps fail, but most of what I've read indicates that they are usually good for somewhere between 100k & 200k miles, and some go well over 200k miles.
When I got my truck it smoked and clattered and had no power. The recommendation was to replace the pump, and I even bought one. Fortunately I tried a few other things before replacing it, because the pump wasn't bad - it was just 180* out of time. If I had put a new one on it wouldn't have solved the problem at all.
After getting the pump back 180* it ran much better, but still smoked on deceleration. Again, several people made the same recommendation - replace the pump. A little more investigation revealed it could be a timing issue - and it turned out that it was timed about 10* too slow. Spectramac helped me correct that and now it runs pretty good, just idles a little rough.
To fix the rough idle several folks recommended replacing injectors - about the second most expensive part in the system. I put a good dose of Diesel Kleen in the fuel, and the more I drive it the better it seems to be getting.
None of this is to say that I may not end up needing to replace the pump, and/or the injectors eventually. Just to say that replacing expensive parts isn't always the best first step in diagnosing or fixing problems. There are a number of other diagnostic steps to try first - things that cost little or even nothing but time to try.
Again, PLEASE, don't ANYONE take me wrong. I'm still a noob with a LOT to learn from the folks around here. I just want to suggest that it is often a good idea to try the less expensive diagnostic steps first before replacing expensive parts.
2001cougs, is it using any oil? Has it improved at all after servicing the CDR and air cleaner? Any possibility of air intrusion? I've seen other threads saying that air mixed with the fuel will produce white/blue smoke.
Another possibility is that it could have dirty/sticky fuel injectors. For that the first thing I'd try is to run a couple of tanks of fuel - with a good dose of Diesel Kleen or something similar in it - through it and see if it improves.
If the problem still persists then next I think I'd have the timing checked at a reputable diesel repair shop (or by someone like Spectramac
).Just my $.02
I get a lot of practice typing, so yeah, I'm fairly good at it and fairly fast.
If typing is somthing you struggle with, I guess I can understand what you're saying about giving the shortest answer possible.
Again, no offence intended. The main point I wasnted to make is that replacing the most expensive parts in the system isn't usually the best first step.
First off get the truck up to running temperature. Get a test light or voltmeter and a three foot jumper wire. Remove the cold advance solenoid wire from the top of the IP (injection pump), this is a single wire. Start the truck (be very careful – no long sleeves or anything that can get caught in the fan or belts). Using the meter or test light check to see if there is power on the wire you just disconnected from the IP, if the truck is at running temp you should not have any power. If you have power then the sending unit might be bad. Next run a jumper wire from the positive terminal of the battery to the spade connector of the cold advance, does the engine sound different? If the timing of the IP if way off you may not notice a change with out a meter attached.
Next make sure the mechanical advance is not stuck, to check this look at the top - front of your engine, on the lower right hand side of the IP there is a lever that moves left and right when the throttle is moved. With the engine off does this lever move left when you manually move the throttle linkage on the upper left-hand side of the IP? If the lever does not move use penetrating oil and see if you can work it loose, if the lever moves start the truck. Be very careful – no long sleeves or anything that can get caught in the fan or belts – you know the drill. While the truck is running take a screwdriver and push only the lever on the left. Does you engine do anything? If not the internals might me gummed up. Power Service diesel klean seems to be the fluid of choice for getting these unstuck (if possible). If the advance looks good we’ll move on to timing.
93
just kidding, good advice.
